.Stang|ess said:there should be no difference since they're both 460 watts correct?
They mean physical amplifiers, not amps the measurement. The Mach 460 has two additional amps located under the package tray in the trunk.Stang|ess said:I'm rusty with my physics equations, but does watts affect the amount of amps? if not, there should be no difference since they're both 460 watts correct?
if the above is true, I'm gonna agree with tom, and say your system is old and worn. buy some speakers and see if that helps, if not return them.
Uncle Meat said:They mean physical amplifiers, not amps the measurement. The Mach 460 has two additional amps located under the package tray in the trunk.
U.M.
A Ford is the best? You better believe it. Although we had only limited seat time in this pony two-door, it was long enough for this sound system to part our hair without a comb. It's that good. And loud — we mean, really loud. The GT Premium comes standard with this system, known as the Mach 460, which includes an in-dash six-disc CD changer, eight speakers, three amplifiers and 460 watts of total system power. If your ears aren't bleeding from the Mach 460, you can order the Mach 1000 (MSRP $1,295), which has six amplifiers and 1,140 watts of total peak power. But be forewarned: The neighbors will be ticked if you play this thing in your driveway.
