19lbs enough?
  • Thread starter Thread starter 88hatchblack
  • Start date Start date Jun 5, 2005
88hatchblack
163
Willard, Ohio
Jun 5, 2005
  • Jun 5, 2005
are 19lb injectors big enough for my setup? i'm having mixed feelings- more fuel with the 24's vs. better spray pattern with 19's at high psi. what do you guys think?
nito88stang
2,012
Fullerton, California
Jun 5, 2005
  • Jun 5, 2005
19's should suffice with a bump in fuel pressure, id still get it to a dyno and see what the wideband says though. Better safe than sorry.
A
airflow89
  • Jun 5, 2005
19 lbs should make 375 hp.
I have 19 # injectors on my stang and they work well. I had 24# injectors the car ran rich and stunk of fuel. The mods Edelbrock intake, heads, 2.02/ 1.90 .545 lift, bored 30 over, MSD ignition, and so on. I don't race so others would say go with the 24#. To little fuel is more dangerous than to much. Starve a motor of fuel, tached out, baboom!! If its a daily driver with basic mods, 19# work. Occasionally I beat her and things are fine, good luck. One more thing get a good fuel presure reg. I run my a hair under 40lbs.
Scottie
88hatchblack
163
Willard, Ohio
Jun 5, 2005
  • Jun 5, 2005
thanks for the help!
jb89coupe
416
CT
Jun 5, 2005
  • Jun 5, 2005
See sig, even with 100 shot (dry) I've never leaned out with 19's.
C
crunchie12268
599
Manhattan, KS
Jun 5, 2005
  • Jun 5, 2005
yeah, I think 19's are fine, you can get some good deals on 24#'s though.
Stang89LXCPE
88
Wooster, O-HI-O
Jun 5, 2005
  • Jun 5, 2005
Stick with the 19's for better driveablility, throttle response, and milelage. You'll be fine with 19's. My car ran much better with the 19's, but i never had it on the dyno with them to see what the A/F ratio was like.
Of coarse, if you feel the need to step up to 24's, get a good meter from pro-M or the new guys that took over. A crappy matched meter even with a chip burned is still not good.
C
Engine Cylinder 5,,7, & 8 run significantly cooler than the other cylinders
  • Crisfixes
  • Sep 27, 2025
Fox 5.0 Mustang Tech Sep 27, 2025
Fuel 19lbs EV6 fuel injectors, what fuel pressure???
  • PonyGTrider
  • Jul 11, 2024
  • 6 7 8
12K
Fox 5.0 Mustang Tech Jul 25, 2024
PonyGTrider
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
J
Fuel Fuel Pressure Issue
  • justadude07
  • May 12, 2025
Fox 5.0 Mustang Tech May 12, 2025
justadude07
J
O
Good all around perfornace-ish tires?
  • optionizerSS
  • Jan 25, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 15, 2026
TPony
