OK Folks ... this one is gonna be long
but
Thats just how it is
I've shared the 1 rwhp/1 ci rule of thumb thing on here many times
I've also said as you move above the 1 to 1 ratio ........
you will start to suffer with drivability issues
Here is where I wanna frame my statements
and
They are based upon my findings with the following things in place:
1) OEM block ... the pan has never been off my GT
2) Naturally Aspirated Combo
3) Self Tuned by Tweecer
The focus with my 95 GT has been on a STREET APPLICATION
A few of my goals were:
a) 300 SAE rwhp peak
b) 300 SAE rwtq or better from very low to the upper end of rpm range
c) All emissions equipment in place and in good working order
d) All accessories in place and in good working order
e) No drivability issues such as bucking, surging, stalling, etc
As for goal a) ... I fell a bit short
I've upgraded the tb & maf
I do feel I've made it to 300 but haven't been back to the dyno
I do wanna make it very clear my combo drives like a little stocker
Stang in every way except it has more power and lopes a good
bit at idle ... but .... it is a consistent & stable lope
The above is my definition of a Street Car with all options in place
I also wanna focus on the torque curve
which for me was a M U S T have kinda thing :Word:
Also ... I wanna point out my stipulation of using a SAE dyno cal is what
I feel to be of great importance.
Several years ago ... almost all dyno pulls were caled with that method
As time passed on ... you now see more and more done with the STD cal
which usually produces results that are higher in value than the SAE cal.
Now ... that you have a clearer understanding of what I was
able to accomplish with my little GT
Let me say I ain't trying to brag
but
Show what can be done with ........
some help with the selection of combo parts ... Thank you Ed C
and
the optimization of the pcm ... Thank you Tweecer
Lets mention a few things I've seen from other combos
Its all about application and goals
Some of the time ...
Its just not fair to try and lump em all in the same group
Quick Example
Lets talk about a purpose built, blueprinted and balanced short block.
I feel that has got to be good for around 10 rwhp as it is more efficient
than the OEM sb as built from Ford
Having said that ... see how a guy with a b&bed 306 is not really in
the same category as the OEM blocked combo as he starts out with
around a 14rwhp advantage
I WILL NOT consider those combos that have
very soft low ends
are more at home on a track than street
don't have all accessories
OR
any other compromises to gain higher dyno results
AND
do not meet my above guidelines
Peeps who have combos that fall outside of those guidelines
certainly could drive their cars on the street and call their
combos a ... Street Car
I got no prob with combos like that
They just are not in the same category as I am IMHO
and
I've not had the opportunity to see how effective I could tune one
OK NOW ... Lets shift gears here and talk about more than 1 to 1
I said you will see drivability start to suffer
The following ... speculation ...........
is based upon my my findings from working with my 95 GT
so
Please understand I've not actually done what I'm about to lay out here ...
I feel you could take a combo as I described in the above guide lines
1-3 and go to around 350rwhp with drivability still ... pretty good.
The key things would be more aggressive cam
and
an intake with more flow
HOWEVER
Most likely gonna have to lope a bit more at idle
Most likely gonna have to give up a tiny bit of low end tq
maybe not
Lastly ... I'd like to mention a few things about drivability
I wanna first say I could not have gotten the results I did without
the ability to access the pcm with my Tweecer :Word:
I was able to work on issues ... one by one
until
They were A L L gone
Folks ... my cam was cut with a lsa of 109 degrees
For several years now ... and ... still to this day .......
Peeps say cams with low lsa's just won't work with a 94-95 pcm
I have seen some say they got a chip burned by a Pro and it is good
but
It still does this or that
I suspect ... some or all of that ... could be dealt with by more time
spent with the car ... but ... that is one B I G difference between the
two methods of tuning.
A guy like me who is setup to self tune can spend more time to work
out issues like that and a Pro can only do so much with the time you
are willing to pay him.
No doubt about
WOT tuning is cake
compared to
Tuning for drivability issues
Well ... I hope I've cleared up some stuff I've said in the past
and
AS ALWAYS ... I've made someone ... somewhere ... think ... Hummm
Any comments are welcome
and
If I need to be more specific on something I said ... just speak up
Grady
