OK guys, let me pick your brain for a minute and test my theory.
I am planning a 5.0 swap when the 2.3 in my 93 LX dies. What I would like to know is: Can it be done?
I'd like to be able keep the factory cruise control from the 2.3. The trans will probably be an AOD because I already have a good one that came with the engine I picked up. Now, the cruise control box is a separate unit mounted on the passenger side strut tower, correct? The AOD has a Vehicle Speed Sensor on it that could be made to work with that control box, or I could get a box from a 5.0. Also, there needs to be a vaccum signal for this control box to determine engine load I assume? If I hook up the VSS in the new AOD to the control box, and connect a vaccuum source to the control box, I should have the ability to have cruise control, right? I know I'll need a way to hook up the servo to the throttle cable, which I have to deal with anyway because I will need to refab the original cable or get a different one to work with the carb anyway.
So do you think it will work? I hope I was able to clearly explain what my thoughts are on this. Any ideas, theorys, problems, complaints,
flags
are all appreciated! Thanks!
flags
