2.3 Engine Bay Wiring
raun93lx
21
I have read numerous of sites and pages on this but can someone just let me know what wiring and etc needed for my swap. I have a 93 2.3 5 speed to where im going with a 5.0 Carb swapped. My plan is to eliminate as much as i can to have a clean engine bay with out having wires that not needed. SO my question is what wires is needed
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,395
5,479
203
44
You can do that swap with none of them. You need the headlight harness...and a bunch of stuff on the starter solenoid. Get a gm style vacuum advance HEI distributor for a mustang. If you run an electric choke carb you'll need to run those wires. Getting factory gauges to work is a harder task.
raun93lx
21
thanks so my question is i got the headlight harness but what do i need to extend for the alternator, and what wire needed to get power to my ignition
90sickfox
Mar 2, 2015
6,395
5,479
203
44
I've never attempted to use the 4 cylinder harness. The alternator wires should be green, yellow, and white / black stripe. The green wire is the one that triggers the battery light in dash. The temp sender wire could be retained also. I have no idea where to find these wires in a 4 banger harness.
raun93lx
21
ok ima have to find the wires for the 4 banger and sort them out so i can get to this i appreciate you for responding
