2.3 to 5.0 cluster swap question
No, I haven't touched anything for the 5.0 swap under or in the dash yet. Would it be easier to just get a 90-93 cluster......crap now that I think about it the cluster will not work because in the 88 its flat and mine is rounded.....hmmm would a 90-93 be a direct go? someone said the speedo will read twice as fast if i leave the 4 banger cluster in there.
man i really dont know,i changed every wire in the car when i dont my swap and i was going from a 93 four banger to a 90 motor and harness.everything in mine once i got 9it changed pluged right up so i did run into the problem you are having
Grrrr, everyone has a pre 90 and swiches to a 90-93 cluster or even swap but noone swaps from a 90-93 to an 87-89. Could I just swap in a 90-93 5.0 cluster? Or would the computer read it wrong? What about swapping out the C250 and C251 from the 88 onto the 93?
The tach wont read twice as fast. It will read norm because you swapped all your V8 engine harnesses and what not. it will read just fine. I am pretty sure it is plug and play . the only thing I can think of that might not work is the gas idiot light that comes on when you are low on gas. I think that stopped in 89-90. So if you have that now you wont anymore. It is hard to say because supposedly the wiring harnesses are different under dash (so I was told). Good luck man. My car is an ex 89 GT power train in a 88 4 cyl body. So i know that work that goes into that. But I loved it an it only took me a few days.
