2.3T compression
well, one rule of thumb is that all the #'s be within 10% of each other which those definitely are.
why'd you do a compression check?? having problems still??
I'm pretty sure I'm way off but I think I remember the #'s as supposed to be either in the 180's or right at 200 or so.
but like I said, if you're not having problems and it's running 10% on all cylinders, you should be good.
Good, I'll keep the boost under 20 to avoid the joy of a headgasket replacement. Glad to hear compression is within specs.The car is running great, I just did a compression check to see where I was at. I beat a modified 2002 WRX!!! By the way my license plate on my 92 LX vert with the 2.3 turbo is: LIL4CYL
