5.0 from an '85 HO stang going into a '90 Mazda RX-7 convertible
Oil Pan:
The double sump oil pan is hitting my sway bar. Some folks who have done this swap have replaced the sway bar with one that dips lower, costs around $270-$400. I was wondering, is there an oil pan option with a shorter/thinner front sump? Why does this need to drop so low? Oil pan prices I've seen are much less than the sway bar prices (<$100).
Pulleys:
Right now all that's bolted to the block is a v-belt main pulley, and a water pump with no pulley on it. The water pump protrudes past the main pulley (see attached pic below). I have yet to bolt on the a/c condenser and alternator, not sure what pulleys they have on them. Someone suggested a rear-offset pulley for the waterpump (pic below), and someone else suggested I switch to '94-'95 serpentine belt pulleys. He said the serpentine pulleys are also closer to the block, but then wouldn't I need a shorter water pump?
What's the best option here?
Oil Pan:
Pulleys:
