200 I6 Carb ?
  • Thread starter Thread starter 68keyblr
  • Start date Start date Aug 23, 2005
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Aug 23, 2005
  • Aug 23, 2005
The time has come to either rebuild the 1v carb on my wife's '67 vert (200 c.i. I6) or buy a new 2v carb for it. I'd like something with electric choke and that will give her a little more power.
Can anyone recommend a good 2v carb w/ electric choke for this engine?
Cobain03
996
Lexington, Ky
Aug 23, 2005
  • Aug 23, 2005
eer thought about a stock 289 carb? the 300 cfm? how many cfms is the 1v?
J
JB66
565
New York
Aug 23, 2005
  • Aug 23, 2005
If it's completely stock and you want to keep it that way, check out http://www.ponycarburetors.com/
rbohm
6,698
550
204
tucson,az
Aug 24, 2005
  • Aug 24, 2005
there are two ways to get a 2v carb on your 200;
1: get an adaptor available from stovebolt engine co.(yes a gm parts sight but the adaptors and carbs work on fords also) and use an h/w 5200 carb.
2: take the head off and have it modified to allow you to bolt on a 2100 autolite or 2300 holley carb.
the adaptor is cheaper to do. the other thing you can do is adapt the carter one bbl carb from a mid 70's granada with a 250, or from a ford truck with the 240/300 six.
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Aug 25, 2005
  • Aug 25, 2005
Thanks for the info - I happen to have an Autolite 2100 from my '68 302 laying around. I think I'll give the adapter a try
Kriek
57
Dallas, TX
Aug 25, 2005
  • Aug 25, 2005
I found this article on Ford Six Performance (fordsix.com) that you might find useful. It shows adaptars from both Clifford Performance and Stovebolt Engine company, Inc. Hope it helps you.
rbohm
6,698
550
204
tucson,az
Aug 26, 2005
  • Aug 26, 2005
if you want to adapt the 2100 autolit to the log head, contact www.fordsixparts.com as they have an adaptor that should work. it will still require machining the head though. to my knowledge there is no adaptor that will let you bolt a 2100 autolite to the log head. the clifford and stovebolt adaptors bolt a 5200 holley/weber carb to the log head.
J
JB66
565
New York
Aug 26, 2005
  • Aug 26, 2005
I found too, that some of the early econolines had a larger bore Autolite installed. I think I have one that I used for a 200 in my garage. I'll check it out and get back to you with the specifics. I remember it gave a bit more hp to my 200.
C
WTB/Trade Need AC Cutoff Switch for 1984 Fox with 5.0 Manual Transmission and carb
  • CharlieGP
  • Jun 25, 2024
Fox Body Mustangs For Sale (1979-93) Jul 15, 2024
sparkylawdog
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
J
68 Mustang with Foxbody Engine Stalling Issues - MSPNP2
  • JayV68Stang
  • Mar 13, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Mar 13, 2025
JayV68Stang
J
