2000 Mustang 3.8L battery drain
Jl74526
Maryland
I did a drain test found out fuse number 6 in my engine compartment box 40 AMP It’s the instrument cluster, pcm. This has current when key is off Do you know if this is supposed to have current. And how would I find out if it is the PCM or something is shorted in my cluster? Thank you
brucelee
nc
hello, I'm having same trouble, I've noticed the theft light flashes when the switch is off. could this cause my energy loss. and if it is, how do I fix it? would appreciate any suggestion. thanks; brucelee
General karthief
Mod Dude
Aug 25, 2016
11,236
3,421
193
polk county florida
i think this is the wrong forum for this but let me help you out, the theft light should flash with the key off. Have you checked the condition of your battery?
i'll move this for ya'll.
wmburns
SN Certified Technician
Aug 14, 2009
5,061
369
164
Houston Texas
IMO the problem is unlikely to be in a fuse out of the the battery junction box (BJB). The BJB is full of "always on" circuits that feed other circuits. Your time is better spent looking at the Central Junction box (CJB).
1999-2004 MY fuse panel schedule:
https://www.allfordmustangs.com/for...r-swap-wont-fire-please-help.html#post2669271
Here's some information on how to perform a "voltage drop" test. Use the voltage drop method to "infer" the current through each CJB=F2 fuse by measuring the voltage drop across each fuse. The amount of voltage drop is less for larger fuses. There are tables for this. With everything off record the voltage drop across each CJB fuse. Use the fuse number scheme in the fuse panel schedule. Once the fuse is known the next step is to follow down what the fuse supplies.
Howto perform charging system voltage drop test
https://www.stangnet.com/mustang-fo...perform-charging-system-voltage-drop-test.56/
Note, if looking for an educated guess look first at the radio and/or the amp.
Mar 24, 2017
14
I have the same problem,I found a ground wire that is bolted to the fuse box under dash,it is a ground for my stereo sub woofer,factory system.i have not found a fix yet..since I unbolted it,my battery no longer drains out over night.
