2000 Mustang Shifter Cable
tfaughn
Hello everyone. The shifter (automatic) on my 2000 Mustang is really hard to move from gear to gear. A mechanic friend of mine told me that I should replace the cable before it breaks. Has anyone ever done this before that can give some advice before I try it. It doesn't seem like it should be terribly difficult, but I thought I'd ask here before starting the job. Any advice, tips or tricks is appreciated.....even if the advice is to take it to a mechanic!
Thanks
automatic transmission shift cable removal
The instructions in the Ford service manual look very straight forward.
Cable and Bracket
Removal
Raise the vehicle on a hoist. For additional information, refer to Section 100-02 .
Remove the cable shift from the shifter lever and bracket and discard the clip.
Remove the bolt from the cable.
Disconnect the transmission range selector lever cable from the TR sensor lever.
Remove the transmission shift cable bracket (7B229) from the transmission.
Remove the bolts.
Remove the bracket.
Installation
NOTE: It is necessary to install a new plastic clip prior to installation.
To install, reverse the removal procedure.
Cable Adjustment NOTE: Make sure that the range selector lever is tight against the rearward overdrive stop.
Place the transmission range selector lever in the overdrive position.
Raise and support the vehicle. For additional information, refer to Section 100-02 .
Loosen the manual control lever nut.
Place the transmission manual control lever in the overdrive position.
Tighten the nut on the manual control lever.
