got a few questions before i start mine next week.
first of all, what kind of timing cover bolts do i need? i have regular 10mm bolts for the 2000 years, but apparently i need 2 studs or whatever for the coil packs. can i reuse my old bolts that hold on the coil packs? or do i need the 10mm bolts, since mine now are 8mm. do they even make these since there are no 2x2 coil-packs on these years? how did you all do it?
also, do i need a new crank pully bolt?
i just need all info from 99/2000 headswappers only (i believe only these years have the 10mm timing cover bolts, versus the 8mm). any help is greatly appreciated. thanx!
can someone fill me in on this???
the 00 heads are windsor. i know my 00 heads need 10mm bolts.
