Thanks for your response. That is my gut feeling also. Just looking for some other opinions. Did you change your throttle body? Small $$ for a little extra boost as far as I can tell.
Mine is a 2K GT, but no, I have not changed the throttle body...my reading suggests there would be no real power gain with a stock motor. When I purchased the car, it needed an intake manifold due to a crack in the thermostat crossover, so I did put on a Ford Performance piece (I guess technically that was a performance mod). The previous owner handed over an in box cold air intake, which I installed...but, it became a hassle and I ended up going back to the OEM unit. I modified the snorkel to still draw cold air from the fender, but it now has an opening 4-6 times the factory opening. The only other thing I've changed on the motor was to add a home brew oil catch can in the pcv line bc the old intake had a lot of oil in it. I installed a cat back system because one of the OEM tailpipes was crushed.
That said, where to gain performance? I do not know what else you have done to your car, but having been down this hot rod road more than once, and having had cars that just smoked the tires away, I decided to concentrate on getting every bit of available power to the ground with minimal loss. I live in a mountainous area, so cornering prowess was also something I wanted. An SN95 is a 20ish year old car, making most of the
suspension pieces near or past usable life. Mine is a convertible as well, so the twist, flex, etc of the chassis is something I dealt with right away installing front and rear shock tower braces and subframe connector--now it is quite stiff. In addition, I installed Koni shocks and struts, larger front and rear sway bars, and replaced the upper and lower rear
control arms with performance units. I kept the stock springs bc of rough mountain roads, railroad tracks, etc. it handles like a go cart and is plenty fast (as well as reliable).
All said, decide what you expect/want out of the car, then plan the steps/pieces you need to make it that way. Have fun.
