Question......
My 2001 GT is going for inspection soon and I noticed the other day that my mufflers were wet with something. Closer inspection revealed that I am leaking brake fluid from the metal brake line that runs from the front of the car to the rear! It looks as though it was damaged right above the pass. muffler (it's the one that supplies the rear pass. caliper). Previous owner (idiot) took a rubber hose and electrical tape and tried to mend it! I cleaned the area but didn't desturb the damaged area because it isn't leaking bad (fluid level is still good and pedal feels great). So I didn't want to make it worse. The bad thing is...I also don't know how severe the damage is (pin hole or slit in half)!
I was looking all over the net for a factory replacement line and can't find one (any idea's where to look??)
It goes for inspection at a local Ford Dealer (Phillips Ford) soon and I will let them mess with it. Just curious what this might cost to fix and part availability!
I quess this line can't be repaired they will need to replace it huh!
Any idea on cost to replace it???
Thanks...Sorry for all the questions........but since I can't find anyone that sells it I have no idea what they cost and what a garage may charge to replace it!
