Expired 2002 Mustang Gt Clone $19,500 609rwhp 585rwtq
Greg Ring
2001 Terminator GT 609RWHP 585RWTQ... Leather interior, Tilt wheel, Power windows & doorlocks, Cruise, Mach 460 am/fm stereo w/in-dash 6-CD changer, A/C, dual powered mirrors, powered driver seat, Billett Aluminum cluster bezel, cruise control buttons, climent control knobs, mirror control knobs, shifter bezel, window door & lock buttons, door handles, E-brake handle and Cobra Billett pedals. 37,200 original miles/two owner, Garage kept -- never seen rain or snow, car has never been Track driven, car has clean title and has never been in any wrecks. 04 Cobra motor (stock) 9,000 miles Tremec T56 trans with upgraded input shaft (9,000 miles) New Aluminum Spec fly wheel & level II-plus clutch Steeda Adjustable clutch cable & quadrant (Firewall) MGW short throw shifter, Steeda handle Stock Cobra aluminum drive shaft Drive shaft safety loop New Eaton Posi differential New Ford Racing 373 gears New Moser c-clip axles Kenny Bell twin screw (4,000 miles) Fluidyne heat exchanger Steeda oil separator Metco Motor Sports 6 lb lower pulley & idler pulleys, 90 mm 60 lb injectors New stock 04 Cobra tank & fuel pump Kenny Bell boosta pump Accufab throttle body & power inlet JLP inlet tube & cold air kit Granatelli coil-on-plug kit with coil packs Full Bassani exhaust, Midlength headers Ibach lowering springs Tokico adjustable shocks & struts(8way&10) Tokico Quad shocks Maximum Motor Sports caster camber plates Steeda Bump-steer Kit Tubular K-member AJE front tubular control arms (spring cups) Kenny Brown Matrix system (sub frame connectors, jacking rails, frame ties) Kenny Brown solid rear upper & lower control arms Steeda heavy duty front sway bar Baer front 14" track brake kit Baer rear 14" cross drilled rotors Steeda 2.5" fiberglass cowl hood New Mach I chin spoiler New Hypercoated FR500 wheels (18x9) front, (18x10) rear NITTO Extreme performance NT555 tire (265/35-18) front NITTO Extreme performance NT555R drag radial (305/35-18) rear New SLP linelock kit - Still in box Steeda aluminum battery trunk relocate kit Auto meter boost & fuel gage in dash cluster Vortec Intercooler reservoir Tuning done by Kenny at Modular Depot TEXT/call me @ 513-379-7626 CAR IS MINT AND VERY FAST! CASH ONLY NO TRADES DONT ASK! NO DREAMERS AND NO STUPID LOW BALL OFFERS, I DO NOT NEED TO SELL!!! CLEAR TITLE IN HAND. Second owner...THANKS FOR LOOKING..........I can send more pictures if requested.
