ok guys short and sweet what all is needed to do the swap i have my hands on a full motor and engine harness and ecu will the v6 five speed trans bolt up?and the cabin harness i the same right? i know you can run the v6 rear end but i know the specs are not the same but on a dd car it should work just fine?but besides what i said above what els will i be missing the motor mounts are the same right and in the same spots? why am i seeing things about changing the front end and shocks? will the not hold the load? either way any info is appreciated
