2003 Convertable Leak?
KristiLea
I have a 2003 Convertable and I am getting water in the "trough" behind the passenger seat. Any ideas/solutions on how to repair? Top has pulled away from nack glass (epoxy) and went thru car wash but saw no visible leaks. Please help.
Thank you.
the bottom corners of the back glass are common points of failure. Sometimes some silicone sealer will help, but I think the only 100% fix is to replace the top and glass.
Thank you. I figured that was part of it and plan on sealing the top back around the glass but not sure what to use. Epoxy or something? I am also going to try and find the actual leak.
