2003 mustang GT cranks but doesnt start
peste19
About half a year ago i was driving and my car started choking and it stopped on me, I had to call a tow and had it tow home. A few days later i tried to turn it on again and it started.
I then replaced the fuel filter and used seafoam to help clean up injectors, fuel lines etc.
Yesterday about half a mile from home, my car does the same behavior again, started choking and shut off on me.
I was suspecting it might be the fuel pump so i checked the fuel pressure with the Torque app and i have fuel pressure so that makes me think its not the fuel pump. If it was the pump, i would think i would have no pressure.
Any ideas what might be the culprit of this behavior?
thanks in advance
  • Sponsors(?)
Sluggie24
135
22
28
45
Easy way to check crank sensor is try to start car and watch the tach. If the tach is moving the crank sensor is working.
wmburns
SN Certified Technician
Aug 14, 2009
5,838
505
194
Houston Texas
You may not believe this but look at the battery, battery cables, and alternator.
Howto perform charging system voltage drop test
Regarding a possible fuel system problem, why guess? Test! Any problems with fuel flow will show up in the STFT and LTFT's as well as the fuel pressure.
ForScan ODB2 scanner w ELM327 USB
Another easy way is to look at the check engine light during cranking. When the key is on, the check engine light should be on. The check engine light should go out during cranking. This indicates the PCM is alive (at a basic level) and is receiving a CKP signal.
Thread starter Similar threads Forum Replies Date
T No power to the MAF Sensor 1996 - 2004 SN95 Mustang -General/Talk- 0
M 2003 Mustang Gt Starting Problem Cranks No Start First Try SN95 4.6L Mustang Tech 3
S 2003 Mustang adjustable illumination fuse keeps blowing SN95 V6 Mustang Tech 1
J 2003 Mustang Brakes Pulling The Welcome Wagon 4
J 2003 Mustang Brakes Pulling 1996 - 2004 SN95 Mustang -General/Talk- 0
W Mach1 2003 coolant leaking rear of engine SN95 4.6L Mustang Tech 2
D Progress Thread 2003 mustang gt Rebuild 1996 - 2004 SN95 Mustang -General/Talk- 10
94chirps 2003 Mustang door speaker plug Mustang Sound & Shine All 1
H 2003 mustang v6 tick on start ups. SN95 V6 Mustang Tech 5
nathanruschill 2006 Mustang GT mach 1 tribute 2005 - 2014 S-197 Mustang -General/Talk- 8
M 2003 GT auto shifting SN95 4.6L Mustang Tech 0
94chirps 2003 Mustang radio install Mustang Sound & Shine All 0
C Hi guys i just got a 2003 mustang gt 4.6 how do check kow it the car has pi heads SN95 4.6L Mustang Tech 6
F Electrical 2003 Mustang GT - Brake and Blink Fuses Blow SN95 4.6L Mustang Tech 7
Harveyj1965 Hello my name is Harvey my question today is under the hood fuse box I have a 2003 mustang GT edition centennial convertible under the hood fuse bo 1996 - 2004 SN95 Mustang -General/Talk- 0
H 2003 Mustang GT 4.6L Intake Manifold leak SN95 4.6L Mustang Tech 0
C Theft sign solid; car won’t start. SN95 4.6L Mustang Tech 2
C SOLD 2003 SVT Mustang Cobra, Sonic blue SN95 Mustangs For Sale (1994-04) 9
L 2003 mustang gt 1996 - 2004 SN95 Mustang -General/Talk- 8
F For Sale 2003 Mustang GT Vert with very low miles (21K)-Well taken care of SN95 Mustangs For Sale (1994-04) 1
K Clutch Squeal when clutch pushed in 1996 - 2004 SN95 Mustang -General/Talk- 1
P 2003 mustang 3.8L v6 1996 - 2004 SN95 Mustang -General/Talk- 0
F Anybody have experience changing halogen headlights to HIDs or LEDs? 1996 - 2004 SN95 Mustang -General/Talk- 3
03GThoopty Progress Thread 2003 Ford Mustang GT Build Log 1996 - 2004 SN95 Mustang -General/Talk- 101
J Paint and Body What is the hood of a 2003 mustang gt made of? 1996 - 2004 SN95 Mustang -General/Talk- 1
S For Sale 2003 Mustang gt wheels Wheels Tires Brakes 1
0 2003 Ford Mustang V6 3.8L gets around 12mpg and seems to shake a bit when started cold and has a bad rough idle when warm SN95 V6 Mustang Tech 5
N Deciding on which rims and tires to buy so there is no gap in the wheel well. 1996 - 2004 SN95 Mustang -General/Talk- 0
F 2003 Mustang GT not starting 1996 - 2004 SN95 Mustang -General/Talk- 3
A 2003 GT 4.6 - Best exhaust from 3 options 1996 - 2004 SN95 Mustang -General/Talk- 3
R Progress Thread 2003 Ford Mustang 1996 - 2004 SN95 Mustang -General/Talk- 1
O 2003 Mustang GT bogging down 1996 - 2004 SN95 Mustang -General/Talk- 3
B new to me 2003 Mustang GT 1996 - 2004 SN95 Mustang -General/Talk- 0
W For Sale 2003 GT Mustang Deluxe - $6500 (Orlando, FL) SN95 Mustangs For Sale (1994-04) 0
E Rear Lights w/Amber Turning Signal 1996 - 2004 SN95 Mustang -General/Talk- 2
I Electrical help! 03 mustang headlights 1996 - 2004 SN95 Mustang -General/Talk- 2
A 2003 mustang GT- Looking at stage 2 cams SN95 4.6L Mustang Tech 1
S For Sale 2003 Mustang Mach 1 5speed Azure Blue 7,000 miles - fully upgraded and mint. SN95 Mustangs For Sale (1994-04) 0
A 2003 mustang gt - Header leak 1996 - 2004 SN95 Mustang -General/Talk- 1
M Mysterious small green cap and a chugging Stang 1996 - 2004 SN95 Mustang -General/Talk- 4
2003DSGGT 2003 lincoln town car motor block same as the 2003 mustang gt 1996 - 2004 SN95 Mustang -General/Talk- 6
L 2003 Mustang GT 5.4L SOHC engine swap 1996 - 2004 SN95 Mustang -General/Talk- 0
J Mustang 2003 GT - Oil Pressure Switch Failure and (SCP) Data Link Fault SN95 4.6L Mustang Tech 3
M need help no bright lights 2003 mustang gt 4.6 SN95 4.6L Mustang Tech 2
0 2003 mustang GT cricket like chirp in rear end 1996 - 2004 SN95 Mustang -General/Talk- 1
J 2003 EcoStang 1996 - 2004 SN95 Mustang -General/Talk- 1
M 2003 Engine Noise GT Mustang 1996 - 2004 SN95 Mustang -General/Talk- 8
true01blueGT 2003 mustang gt only left driver tweeter 1996 - 2004 SN95 Mustang -General/Talk- 1
B Looking For Info On A 2003 Mustang Gt The Welcome Wagon 1
A 2003 Mustang Gt Slow In 3rd Gear SN95 4.6L Mustang Tech 8
