SOLD 2004 40th Anniversary Mustang GT Supercharged / NC
hotpony
922
12
38
Lee County, KY
40th Anniversary red w/ gold stripes, 2004 Ford Mustang GT. 64,000 miles, tan leather 2 tone interior with Autometer pillar gauges (boost/fuel press). Pioneer touch screen DVD player, Mach 1000 stereo system. Relocated, trunk mount Optima battery (had to remove one sub woofer). Manual transmission with Pro 5.0 shifter, aluminum clutch quadrant with firewall adjuster. Flowtech longtube headers, x-pipe, SLP catback with 40 series Flowmasters. Vortech V2 SQ-trim supercharger, Vortech Powercooler, 90mm Lightning MAF, Powerpipe, K&N filter, 42lb FMS fuel injectors, Dragon intake plenum and throttle body, H&R SS lowering springs, Koni yellow adjustable shocks/struts, Summit Racing upper/lower control arms, Energy Suspension motor mounts, offset rack mount bushings, Steeda Full Length subframe connectors with battle box plates, 3.73 rear end gears, new rear wheel bearings and seals/fluid. Deep dish Bullit 10.5 rear wheels with Nitto 555 275 and 315 rear tires, SVT Focus fuel pump, Bullitt front brake kit with stainless steel brake lines.
Car was tuned at National Speed and made 415rwhp/410ft/lb tq. Tuner is an SCT Livewire and the car made 11lbs of boost on the current setup. All the mods on the car are very new, have a ton of receipts and dyno sheets, with a different fuel pump setup, I have been assured the car will make over 450rwhp. I have some parts not installed, such as Spec Clutch, Energy Suspension A-arm bushings, Caster camber plates and a few other things, I also have the non-aftercooled discharge pipe and the stock control arms as well.
This car is located in Richlands, NC, is well maintained and very clean, must see to appreciate! Asking $11,500 obo, Call/Text Brandon @ 808-366-9551
Pics -
Got the new brakes on and it's going through the bedding in process now. I also took the car back down to National Speed in Wilmington and had a driveability tune done, night and day difference! As far as the brakes go, they are WAY better than before, amazing what good quality brakes can do.
