Expired 2004 Mustang Gt - 40th Anniversary Edition
Asking $18,000
The car currently has 47,XXX miles on it. It is my current weekend car, stays covered during the week in the driveway, and is located in Kendall Park (my parents are in Voorhees and it can be brought down there for South Jersey Test Drives). I purchased in October of 2012 and driven 15,000 miles in 3 Years. I have binder of all documented history with over $15,000 worth of upgrade receipts and servicing. It has a clean, three owner title that has spent its entire life as a show/weekend car. I received compliments on the paint at each show I go to and meticulously detailed and washed regularly. Currently use only 93 Octane Fuel and change the oil twice a year. This car has never seen snow in mine or the previous owner's possession. It was dynoed at 274hp/380ft/tq to the wheels early this year in current configuration. Clutch, Flywheel, Clutch Cable, Firewall Adjuster, and Clutch Quadrant were all replaced less than 500 miles ago.
Exterior Modifications:
Redfire Pearl Metallic Paint
Cervini (1995) Cobra R Hood
Cobra Front Bumper w/Fog Lights
Cobra Rear Bumper (COBRA letters filled and smooth)
Cobra Rear Spoiler
Front Grille Delete
Rear Panel Painted Satin Black
Billet 40th Anniversary Badges
Billet Fuel Door
Shortie Antenna
Black 18" FR500 Wheels
Sumitomo Tires with plenty of life left -- 275/40/18 front and 315/40/18 rear
Drivetrain Modifications:
Exedy 400 Stage 2 Clutch
Exedy Lightweight Flywheel
SR Performance Double Hook Quadrant
SR Performance Firewall Cable Adjuster
SR Performance Adjustable Clutch Cable
Roush Short Throw Shifter
Hurst Shift Handle
Ford Racing 3.73 Ring and Pinion
Engine Modifications:
JLT Ram Air Intake
Accufab 75mm Throttle Body and Upper Plenum
Diablosport 93 Octane Tune (Tuner Included)
Custom Cat Back Exhaust
Suspension & Brakes:
Cobra Front Brake Kit
SR Performance Strut Tower Brace
Maximum Motorsports Sport Box
- H&R Springs
- MM Caster/Camber Plates
- Koni STR.T Struts
- Koni STR.T Shocks
- Urethane Spring Isolators
- MM Pinion Snubber
- MM Panhard Bar
- MM Standard Subframe Connectors
- MM 4 Point K Member Brace
- Urethane Steering Rack Bushings
- Front Sway Bar Bushings
- Front Sway Bar End Links
Loose Items Included:
Diablosport Tuner
Stock Ring & Pinion
Stock Shocks
Stock Struts
Stock Springs
Stock K Member Brace
X-Pipe with Gutted High Flow Cats
Old Emblems
Misc Extras
Let me know if you have any questions, picture requests, or video requests.
