2011 Gt 6mt 3.31 Rear Acceleration
Just got this car about 10 days ago and love it. Got it from a dealer and not sure if a full history on the car. Supposedly lady owned.
Anyway. Above 4500 rpm it's a beast (as everyone knows).
From a stand still and no clutch dump, it barely spins the stock 18" tires.
Is this what I should expect?
Have you held the traction control button with break depressed for 10 seconds? The computer turns off everything—traction control and stability control—when you hold it at a stop for 5 seconds, but what we count as 5 seconds is sometimes too fast, so count to 10 or until the dash indicates that the nannies are off. Basically, 390 ft-lb is plenty to rip the traction. I would assume either one of the nannies are still on or you are in the wrong gear. My auto with 3.15 gears and 20-inch rims was tearing through 1st and part of 2nd, chirping in 3rd with a street tune.
Is the lag normal
I didn't have a 6 speed manual. I would expect lag in an auto. I resolved it with a street tune in large part.
But with a 6 speed manual, it is about the gear selection. Can you give us a detailed example? For example:
I'll be rolling at 10 mph in 1st gear.
RPM roughly 3000.
Floor accelerator pedal.
No wheel spin; response lagging.
To me, if you are in 2nd gear at a roll and stomp on it, you may have lag due to gear selection. It all depends on the scenario you are testing with.
But 3.31s aren't really designed for out of the hole acceleration; they are more for top end and mileage. If you want better low-end response, 3.73s are ideal, but a street tune could really help. The ProCal tune from the FRPP claims to give 60 ft-lb low-end torque increase, which is quite the jump in low-end response.
From a 5 mph roll in 1st I get a smudge if wheel spin but not much.
This part doesn't sound normal. Sounds like the nannies are still on, but that doesn't make sense given from a dead start you can roast the tires.
Even in my auto with 3.15 gears in 1st at 5mph I would roast 'em.
Problem is, you bought a used car, and the dealer from which you obtained it probably isn't going to help for free. I would get the car checked out though. That's just me.
