2011 gt radio noise
chriszn13
San Diego
Hello. I recently installed speakers and an aftermarket amp for the door subs and speakers. I've recently noticed an annoying high pitched noise coming from the speakers. It's very faint and It sounds like when your ears are ringing. I disconnected the power line going to the amp and noise is still there but a little less audible. I disconnected the radio fuse and noise went away. Could it be the radio ground? Where is that located? I've double checked speaker connections and everything is good. Any help would be appreciated.
  • Sponsors(?)
chriszn13
San Diego
I got and wired a noise filter to the headunit power and ground and that didnt work. I even ran the amps ground and the head units ground straight to the battery and that didnt work. Could it be the head unit itself? Maybe something internally went bad ?
chriszn13
San Diego
One more thing to add if it helps trouble shoot. Before I changed anything I always had a little white noise through the speakers and some kind of faint rumbling noise through the doors subs when not playing anything and the volume all the way down.
JmP6889928
278
243
53
61
Southwest Michigan
Is your antenna grounded and plugged all the way in? Sometimes, if the antenna isn't grounded, it can generate white noise. The head unit uses the antenna ground as part of the output/amp ground.
Thread starter Similar threads Forum Replies Date
muztangman93 SOLD 2011 And Up Mustang Radio Bezel Hydrodipped In Carbon Fiber Interior Exterior Parts 0
D 2011-2014 dash cluster schematic 2005 - 2014 S-197 Mustang -General/Talk- 0
B 2011 - Strange lock / unlock behavior with key fob. 2010 - 2014 Specific Tech 4
M 2011 GT or 2015 2010 - 2014 Specific Tech 0
Z mustang 2011. 2010 - 2014 Specific Tech 0
B 2011 5.0L, intake manifold wet and strong fuel smell. 2005 - 2014 S-197 Mustang -General/Talk- 0
W 97 Mustang GT to 2011 Crown Vic Swap 95k Miles (Knock at idle) 1996 - 2004 SN95 Mustang -General/Talk- 1
Jordan Warta 2011 5.0 using oil 2010 - 2014 Specific Tech 3
S 2011 Mustang GT Base Potential Electrical Issue 2005 - 2014 S-197 Mustang -General/Talk- 0
H 2011 mustang gt ac problem 2005 - 2014 S-197 Mustang -General/Talk- 1
W 97 Mustang GT Engine Swap From 2011 CVPI Injectors SN95 4.6L Mustang Tech 2
RC Sanders Brembo Brake Pack Retrofit to Automatic 2011-2013 GT's 2010 - 2014 Specific Tech 1
R For Sale 2011 Ford Mustang GT S197 Mustangs For Sale (2005-14) 0
G 2011 ROUSH STAGE 1. The Welcome Wagon 1
R 2011 5.0 Wont start have spark 2005 - 2014 S-197 Mustang -General/Talk- 0
MeyHam413 What Next? Throttle Body or Electric Water Pump 2011 5.0 (H-pipe, Axel Back CAi, E85) 2005 - 2014 S-197 Mustang -General/Talk- 7
D Electrical Need Help!!! 2011 Mustang gt wont start 2010 - 2014 Specific Tech 0
S Headlight Upgrade for 2011 Stang 2010 - 2014 Specific Tech 0
B 2011 Owner - But New Here The Welcome Wagon 1
M Electrical 2011 GT vert. rear window problem/can bus gremlins 2010 - 2014 Specific Tech 1
A 2011 mustang GT 5.0 help!! 2010 - 2014 Specific Tech 0
blackhawkkid308 2011 mustang gt ac problem 2005 - 2014 S-197 Mustang -General/Talk- 0
E 2011 GT shaking when turning 2010 - 2014 Specific Tech 2
JmP6889928 For Sale 2014 Mustang 2011-2014 V6 3.7 Airraid CAI Other Classifieds 0
S 2011 v6 Fault code B0200 2005 - 2014 Specific V6 Tech 2
G Engine 2011 GT 6M - Cylinder 8 misfire 2010 - 2014 Specific Tech 1
A Will a 2011 Mustang GT exhaust fit a 2006 mustang v6? 2005 - 2014 S-197 Mustang -General/Talk- 3
A New 2011 v6 owner, budget mods? 2005 - 2014 S-197 Mustang -General/Talk- 3
White Wolf For Sale 2011-14 V6 Nitrous Plate System - BRAND NEW $800 Las Vegas NV Engine and Power Adder 1
D 2011-Need Help! Electrical issue 2005 - 2014 S-197 Mustang -General/Talk- 1
R 2011 mustang gt with 80k plus miles 2005 - 2014 S-197 Mustang -General/Talk- 0
JROGERBECK 2011 V6 Performance editon 2010 - 2014 Specific Tech 1
T Hello SN! 2011 GT owner The Welcome Wagon 0
M Electrical 2011 Coyote Crate Engine AC problem 2010 - 2014 Specific Tech 1
J For Sale 2011 Mustang GT Premium coupe white/black / 86k miles S197 Mustangs For Sale (2005-14) 1
P Drivetrain 2011 wrecked Coyote won't stay running 2010 - 2014 Specific Tech 0
J 2011 GT Charging System Light won't go off? 2010 - 2014 Specific Tech 0
S 2011 v6 - auto lights swap from 2004 F150? 2005 - 2014 S-197 Mustang -General/Talk- 1
P Drivetrain 2011 v6 - loud and stiff clutch whines 2010 - 2014 Specific Tech 1
Z 2011 mustang gt 2010 - 2014 Specific Tech 0
C 2011-14 x pipe ?? 2005 - 2014 S-197 Mustang -General/Talk- 0
R 2011 Mustang Fuel issue - Loading up 2005 - 2014 Specific V6 Tech 3
R Drivetrain 2011 gt stuck in 2nd 2010 - 2014 Specific Tech 0
L 2011 mustang gt no start 2010 - 2014 Specific Tech 2
L 2011 GT500 Odometer question! 2010 - 2014 Specific Tech 3
JROGERBECK 2011 v6 wipers won't turn off 2010 - 2014 Specific Tech 2
G 2011 Mustang Gt 2010 - 2014 Specific Tech 1
denny j sayers 2011 5.0 mustang manual brembo brake package ! 2010 - 2014 Specific Tech 3
E Mustang 2011-2014 80,000+ Miles? 2010 - 2014 Specific Tech 1
J Expired 1 Of 17 2011 Mustang California Special Supercharged S197 Mustangs For Sale (2005-14) 1
