2100 Autolite Carb
Sweetmarie66
64
45
Hey everyone. Well with some wicked advice and support we have decided to go with the autolite 2100 carb. I've ordered the adapter plate but it says that machining will still be required. We currently have the 1100 single. Duraspark ignition kit has also been ordered to liven the inline up. Couple questions. I think there is going to be some throttle linkage issues and have heard most go to a lokar cable setup. Anyone out there that has done this conversion? Feel free to let me know of how you made out. There is a guy on here rbohm who has been awsome. Hint hint lol. Happy wrenching everyone
  • Sponsors(?)
rbohm
SN Certified Technician
Apr 12, 2002
6,638
536
204
61
tucson,az
piecing together a throttle linkage is always an issue in non stock applications. a cable throttle is one way to go, a lot of guys use a fox body throttle pedal and the lokar cable, or a 5.0 mustang cable. you might have to modify them a bit to work. and you will have to drill a hole in the firewall to run the cable through, along with making/modifying the necessary brackets for the cable.
Sweetmarie66
64
45
Ok. Sounds good. I take it that my stock pedal linkage setup won't work with a cable setup? Be best to just get everything from a 5.0. There are 3 complete 1991 5.0s at my local wrecker.
rbohm
Apr 12, 2002
6,638
536
204
61
tucson,az
well that depends on how resourceful and creative you can be. i have known guys that could cobble together a system you would look at and think that could never work, and yet it does. i have also seen guys that put together a completely stock factory set up, and couldnt get it to work to save the planet. but take a long look at your stock pedal, how is operates, etc. and perhaps you might find a solution to using it with a cable throttle. most of the guys i know tens to take the easy way out and use what is available that has been engineered to work from the factory.
Sweetmarie66
64
45
Ok thanks Richard. Hopeful that it warms up for the weekend so I can visit car basher. I will look into what I've got and go from there. I'll just keep chipping away at the engine bay getting that ready for paint in the meantime. It's amazing how many hours you can spend .
rbohm
Apr 12, 2002
6,638
536
204
61
tucson,az
please dont remind me
Sweetmarie66
64
45
Sweetmarie66
64
45
That's funny. But I'm quite grateful for the amount of time you have invested is classic cars. I'd be lost without Ya!!! Thanks again
Sweetmarie66
64
45
Found a 2100 autolite A-800 for a maverick with the 289 or 302 ,new for 115.00 US. Question. Does anybody no of the hight from bottom of base plate to its highest point? Ive looked everywhere and im stumped. Thanks
Thread starter Similar threads Forum Replies Date
Nick Bos 1970 Mustang 302-2v Carb? Classic Mustang Specific Tech 1
6 Carb Gurus need help quick Newb Autolite 2100 Classic Mustang Specific Tech 6
Skymarshal Help with Autolite 2100 carb! Classic Mustang Specific Tech 4
phendyr Options For Salvaging An Autolite 2100 Carburetor Classic Mustang Specific Tech 3
Dougsters For Sale Autolite 2100 1.23 Vent. 354 CFM Engine and Power Adder 1
Dougsters Rebuilt my Autolite 2100 but have a float level question ? Classic Mustang Specific Tech 4
B Autolite 2100 with stock 87 HO !?! Fox 5.0 Mustang Tech 3
Platonic Solid 2100 Autolite/Motorcraft Rebuild Classic Mustang Specific Tech 3
J Autolite 2100 idle too high Classic Mustang Specific Tech 3
6 Looking for Autolite 2100's Engine and Power Adder 2
6 CFM 2100? CARB 1965 - 1973 Classic Mustangs -General/Talk- 6
david.93 93 cobra I payed 2100 for SVT Tech Forum 10
Dougsters Just rebuilt my 2100 carb. but have a power valve question. Classic Mustang Specific Tech 2
dagenham 2100 2v gasket ID Classic Mustang Specific Tech 3
C stock 200. would a 1.14 2100 be a good idea? Classic Mustang Specific Tech 0
C what size 2100 should I get for a stock 200........ Classic Mustang Specific Tech 2
H No power till i hit about 2100 RPM Fox 5.0 Mustang Tech 22
Platonic Solid Where to buy throttle position solenoid for 2100 Carb Classic Mustang Specific Tech 7
R 2100 carb question - accel pump Classic Mustang Specific Tech 5
S 2100 Carb Re-Jet Classic Mustang Specific Tech 2
L 2100 RPM Idle... 2.3L (N/A & Turbo) Tech 2
JC6715 2100 Float wet level spec? Classic Mustang Specific Tech 1
jordanvraptor S/B and Hooters tonight 6-5-04 2100 hrs Regional Forums and Event Information 4
V Autolite 4100 Secondary Diaphragm Lever replacement 1965 - 1973 Classic Mustangs -General/Talk- 2
T Plugs - NGK or Autolite? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
S Progress Thread C6AF F 6A F 4bbl Autolite 1965 - 1973 Classic Mustangs -General/Talk- 2
M Autolite 1100 1965 - 1973 Classic Mustangs -General/Talk- 4
M Autolite 4100 Trouble 1965 - 1973 Classic Mustangs -General/Talk- 2
Steve491 Expired Autolite Ht1 Plugs, Oil Filters, And Fuel Filter Engine and Power Adder 0
billison Had To Get Autolite 2546 For A 88. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
sen2two Autolite 25 Plugs 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
THEUNDERCOATER Gap For Autolite 25 Fox 5.0 Mustang Tech 5
A Need Autolite 4100 Help Asap.. 1965 - 1973 Classic Mustangs -General/Talk- 1
R Expired Rare Autolite 4 Barrel In Line Carburertor Engine and Power Adder 0
M Autolite 4100 Secondaries Driving Me Nuts 1965 - 1973 Classic Mustangs -General/Talk- 5
skiwesser11 Questions About Autolite Spark Plugs Fox 5.0 Mustang Tech 2
cptawesome 66 I6 Autolite 1100 Install Won't Start The Welcome Wagon 4
Davidx9x Expired Autolites Ht1, Valve/tb Covers, Towr Brace, Cams, Gears, Steeda Ud Pulleys, Tails, Saleen Axleback Engine and Power Adder 1
65-Fstbk Autolite 4100 1.08 Vs 1.12 Classic Mustang Specific Tech 4
ZachMartin68 SOLD Autolite 4100 4 Barrel Carburetor VERY lightly used!!! Engine and Power Adder 4
B Any difference in Motorcraft SP498 and Autolite AP5143 spark plugs? 2005 - 2014 Specific V6 Tech 1
E Autolite Battery Cover - Need Battery Rec Classic Mustang Specific Tech 0
O Flooded Autolite 1100??? Classic Mustang Specific Tech 11
BlackVert Autolite 4100 troubleshooting Classic Mustang Specific Tech 3
BlackVert Rebuilding an Autolite 4100 carb Classic Mustang Specific Tech 16
J Autolite 4100 4V question Classic Mustang Specific Tech 4
G Eight New Autolite HT0 Spark Plugs for Sale Engine and Power Adder 2
madspeed Autolite Sparkplugs....REBATE!! Fox 5.0 Mustang Tech 2
G 4100 autolite carb Engine and Power Adder 0
JC Mustang Autolite 4100 float height, adjustments Classic Mustang Specific Tech 5
