24# injectors= Crappy performance?
  • Thread starter Thread starter 1988WHTGT
  • Start date Start date Oct 12, 2005
First Prev 2 of 2
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Oct 13, 2005
#21
  • Oct 13, 2005
  • #21
33 lbs of fuel pressure held 12.7-12.9 at WOT all the way to rev limiter so dont be afraid to cut the pressure back on it .....
T
TheUser
1,859
Springfield, MO
Oct 13, 2005
#22
  • Oct 13, 2005
  • #22
dwhiskie said:
Your computer still thinks you got 19#. Have a chip burned to the 24#
the computer doesn't know what size injectors are in the car, which is why you have to get a compatible MAF when you change injectors.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Oct 13, 2005
#23
  • Oct 13, 2005
  • #23
you mentioned it popped , have you check and double check the injectors harness to see if any are crossed ? have when you pulled it apart did you pull the plug wires , if so double check them ...even if you have already ....better yet get someone else to check behind you ....
just4bob50
504
Pa.
Oct 13, 2005
#24
  • Oct 13, 2005
  • #24
my brother bought a C&L 76 for his car and he had idle and drivability probs. he tried everything to correct it. He ended up putting his friends pro-m 75 on, and the car immediatly idled fine and drove great when he put everything back to where it was before the C&L. both meter's were for 24lb injectors.
1988WHTGT
270
Guyton, GA
Oct 13, 2005
#25
  • Oct 13, 2005
  • #25
Well, I went out and took off the cold-air, put the stock intake tube on along with a 73mm C&L and it runs pretty good.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Oct 13, 2005
#26
  • Oct 13, 2005
  • #26
I've got the C&L Intake tube and 73MM MAF... with the stock air box with a K&N, with the March ram air kit... It idles perfect, if not better then with the stock meter.
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Oct 13, 2005
#27
  • Oct 13, 2005
  • #27
urban96 said:
get a pro-m
Glad someone else said it before i did.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Oct 13, 2005
#28
  • Oct 13, 2005
  • #28
Yep. Buy a MAF that's not even made anymore... Buy a product from a company that can't keep it's head above water.
2000xp8
Aug 8, 2003
8,075
1,658
194
NJ
Oct 13, 2005
#29
  • Oct 13, 2005
  • #29
Umm, the new pro m company is run the by the same guy that ran the old one.
Same meters.
It's easy for C&L to stay in business when you buy a couple hundred stainless steel coffee mugs, cut holes in the bottom and call them Mass air meters.
Does help that they are major contributers to the magazines too, so they get good write ups, when things really don't go so well. This info from someone that worked at a shop that has done a ton of dyno tests for the magazines.
H
Hawaiian5.0
53
Hawaii
Oct 14, 2005
#30
  • Oct 14, 2005
  • #30
Had the same prob as you 88WHTGT awhile back. C&L makes their MAF's for the stock air box. Cured mine with the stock air box back in and a TPS adjuster plate.
IMO, go with a Pro-M and be done with it!
JUCD 5.0
107
Belleville, Illinois (ST.Louis area)
Oct 14, 2005
#31
  • Oct 14, 2005
  • #31
I bought the Pro-m when i installed the 24lb injectors and it ran fine??
1988WHTGT
270
Guyton, GA
Oct 14, 2005
#32
  • Oct 14, 2005
  • #32
I've got the C&L intake tube also, but the coupling is too big I try to put it on the throttle body. Are they made for larger throttle bodies? I have a 65mm, but that tube seems like it would be better for a 70+
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Oct 14, 2005
#33
  • Oct 14, 2005
  • #33
I had mine of my stock 58MM tb and my new 70MM tb.... fit fine on both.
First Prev 2 of 2
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
Won’t idle after rebuild
  • Brynden29
  • Sep 16, 2023
2K
SN95 4.6L Mustang Tech Sep 17, 2023
Brynden29
Progress Thread Evolution of the 'Hudson Heap' plans (87 GT)
  • MadSquirrelTech
  • Jan 5, 2024
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 26, 2024
