2002BLGT
Well-Known Member
33 lbs of fuel pressure held 12.7-12.9 at WOT all the way to rev limiter so dont be afraid to cut the pressure back on it .....
the computer doesn't know what size injectors are in the car, which is why you have to get a compatible MAF when you change injectors.dwhiskie said:Your computer still thinks you got 19#. Have a chip burned to the 24#
Yep. Buy a MAF that's not even made anymore... Buy a product from a company that can't keep it's head above water.2000xp8 said:Glad someone else said it before i did.
Umm, the new pro m company is run the by the same guy that ran the old one.PoopDawg said:Yep. Buy a MAF that's not even made anymore... Buy a product from a company that can't keep it's head above water.![]()
I had mine of my stock 58MM tb and my new 70MM tb.... fit fine on both.1988WHTGT said:I've got the C&L intake tube also, but the coupling is too big I try to put it on the throttle body. Are they made for larger throttle bodies? I have a 65mm, but that tube seems like it would be better for a 70+
