24 lb fuel injectors?
whitebeast
15
Hi all will you look over my setup and tell me if my car i will run better with 24lb fuel inectors i have a- 155 LPH fuel pump,bored .020 (304)over new pistons crank and rods,E-7 heads with new roller rocker and lifters,(soon upper and lower gt-40 ported intake, TB,mass air)and at the same time thats when i plain on the fuel injectors what do you all think?
CRASH7772 said:
19# injectors...........If your under 300 FWHP, you should be fine.
ditto.
if you are going to plan a good future buildup of all the bolt ons and you came across a cheap set of 24's and the matching meter, then why not but if you aren't going to do all the bolt ons or even right away, then the money could be used for whatever bolt ons you are getting instead.
