if you put 24s on that sd setup you will just be dumping fuel into the motor, it will run way too rich. If you have the stuff for mass air, convert it now, but if you want bigger injectors you need a diff meter. I've got ported heads, intake and a bigger cam and am running stock injectors because im still speed density. A guy on here has the same setup as me and put 24s in his car, ran waaay too rich. I just bought a mass air computer and am going to convert mine this weekend, I would suggest that you do the same.
