24lb Injectors
I have a 2002 GT with an 80mm C&L Mass air unit, Accufab 75mm throttle body and upper plenum, Granatelli Motor Sports Coil on Plugs and Diablo sport tuner.
Other modifications I have are: 3:73 gears, Steeda under drive pulleys, PA-Performance 130amp Alternator, Center force duel friction clutch, BBK off road X pipe and 40 series flow masters.
I want to up grade my injectors from the 19lb to 24lb. What else will I need to change? Fuel pump? Fuel regulator? Calibrate the mass air sensor?
I plan on replacing my intake manifold before the end of the year with the Professional Products Typhoon intake and upgrading my cams, heads and headers sometime next year.
I’ll probably install the injectors the same time I do the intake swap.
Thanks for the help!
