24's enough?
frcefedlx
184
24lb injectors should be enough for 94' Cobra with Twisted Wedge heads, stage one cam, Tmoss ported lower Cobra intake (or Street heat intake) with 65mm throttle body? I have 30's from my old car but would need a calibrated mass air. Should be ordering the misc. parts as soon as intake decision is made.
I'm not disagreeing with Dave..............if you plan on doing more in the future ??????????????
Just a FYI..........I have no trouble with the 24's....my set up is below...........maybe it's in the tune........
Thirty's
I've given my all concerns about ...........
fuel supply components
elevated fuel pressure
pcm intervention
yada yada yada
over and over :dead:
so ........
No need to give it ... one more time
as
the details are still the same now as then :)
Grady
I've been running 24's on my motor for the last two years (the one in the sig). Hell I open track the dam thing...havent had a problem. On the dyno it ran an AFR between 12-13.5 (running on stock cpu, yea I know I need a tune). Your motor seems milder than mine...so I dont see a problem w/ it. The little 24's will go a long way.
I'm going against the grain here and saying they'll be fine. I'm still running 19's with the mods in my sig. Not saying I'm not leaning out up top a little, but I have zero ping on a bone stock GT fuel system...
I am going with the thirty's. I already have them and I would much rather be over injected then under. So for the fuel system I am going with a 255lph pump with a kirban adjustable reg. that is on the car already. Thanks all.
