25 mpg and 350 h.p. - how to do it?
Check my mod list. The one road trip that I've made since doing it, I got 22 mpg with an automatic. I was pretty jazzed. I'd think that after I do my T5 swap, it ought to be near 25 mpg on the highway.
EFI and pressurized induction - Turbo or small supercharger, good tune, 3.55 gears. Keep your foot out of the boost and the engine will run at stock power levels and get great gas mileage.
Trailer the car to the top of a mountain and coast down.
Seriously, the caveat is that while folks do get close to doing what your propose, you have to leave your berries at home in order to accomplish the mileage portion. Folks generally build powerful stangs to have fun with them.
The new cylinder-on-demand stuff is pretty neat and help the future of big motors which otherwise are slow to see tech advances IMHO.
I would say a small turbo would be the key in terms of efficiency. Other than that a gerbil generated auxillary power pack would be my second choice. Just don't let those little buggers loose in your car. They will F you up in short order.
Drop those down to 3.27's and you'd fare even better!
Seriously though…the biggest thing that has help me in those regards is being able to to the low load portions of my VE table to be a bit lean. Stock AFR's typically hang around stoich (14.7:1) while I tune to around 15.5:1. I get around 24mpg and I'd estimate my horsepower to be around 500 at the wheels with my current combo. Of course…of you can't stay off the happy pedal then no amount of tuning is going to help you achieve your goals.
I got 27 on the highway, stock 5.0, T5, car weighs around 2800lbs and stock 2:73 gear but driving a little BELOW the speed limit. In town no matter how granny-like I drive I can't get better than 13mpg... that's shifting at 2500rpm max. I have 3:55's that need to be installed, I'll get better mpg in town and little less on the highway.
Well... that's the question assuming I'm starting with a 87 - 93 5.0 with MAF and stock internals and a T5. What are your ideas?
Maybe not with the T5, but i bet if you stuck with 3.08 gears in the back and switched to a T56, and then turboed it...you'd make gobs of power and still get pretty good mileage. That's assuming that your car EVER got 25mpg though.
I consistently get 25 MPG on the highway with my current setup. I run 3.73's and 24# injectors. Its all about your driving style and speed control. To get the best mileage you DONT need to drive slow. I average between 75 and 85 with current gears and still get 25 MPG. I also have a vac gauge and watch it like a hawk. I tend to go 75 up hills because at 2500 rpm my car barely loads up going up hills. When i come down hills i generally go about 85 and the pedal is just barely cracked open (ie. injectors are basically shut off). When i drive 65 or 70 i only get about 22 MPG. Good mileage can be obtained you just need to relearn how to drive.
The car weighs 3150 with the cage and gas but without me.
Small turbo, big turbo, doesn't really matter. As long as you are out of boost the car will get just about the same gas mileage as before. You will get 350hp easy with good turbo kit, even with all the stock top end stuff. Will need a few other items in order to do it safely though.
Corvette cost much more. Probably not an option....
The t56 has basically the same final overdrive gear ratio so that will not help and possibly hurt with more drivetrain loss....
You do not want to high of a gear that causes you to 'lug' around on the highway...or to low of a gear that causes unneccessary rpm (fuel/air).
I would personally contact Ed Curtis at www.flowtechinduction.com in which he sells custom cams....he can throw a heads/intake package in with it. You tell him what you want - 350bhp and 25mpg - and I bet he can get you close if you get it tuned...
Just my opinion:)
