260 V8 Engines In here- Need Help
  • Thread starter Thread starter 64point5
  • Start date Start date Nov 21, 2007
First Prev 2 of 2
D
D.Hearne
11,730
south louisiana
Nov 23, 2007
#21
  • Nov 23, 2007
  • #21
Low lift/ long duration was a 60's thing. Lots of performance cams back then were like that. The Holman-Moody cam I ran in my 427 was a .515 lift---310 duration solid lifter grind. All Ford's grinds for the 427 were no more in lift, most were .500 with different durations.They've come full circle today with the cams for the Mod motors--- one maximum lift with differing durations. Low lift= easier on the valve train parts.
D
D.Hearne
11,730
south louisiana
Nov 23, 2007
#22
  • Nov 23, 2007
  • #22
Comp Cams lists a 271hp replacement grind ----283/261 advertised duration 228/227 @.050 with a .478/.475 lift (all figures int/exh)
64point5
Atlanta, Ga.
Nov 23, 2007
#23
  • Nov 23, 2007
  • #23
The LAT20 camshaft advertisement from the 60s states that the .450 lift is "at the valve". Would that be more or less at the cam lobe?
For instance, the 271hp replacement cam you cited states .478/.475 do you know ballpark what that would be at the valve? Would it be more or less?
I am trying to figure out whether the site I found is incorrect in their statement that the LAT20 cam is the same as the 271hp cam, or if the difference is in the "at the valve" statement. Any ideas?
Thanks again.
D
D.Hearne
11,730
south louisiana
Nov 23, 2007
#24
  • Nov 23, 2007
  • #24
All lifts I listed were at the valve. Divide by 1.6(rocker ratio) to get lobe lift (on a small block cam) which on that 271HP cam would be .299/.297 at the lobe.
D
D.Hearne
11,730
south louisiana
Nov 23, 2007
#25
  • Nov 23, 2007
  • #25
I looked up the 289HP cam specs in "Ford Performance" and it's listed as a 310/310 duration .460/.460 lift. Ain't no telling which figures are the correct ones.
M
mustangman1974
463
#26
  • Nov 25, 2007
  • #26
danny clemens said:
If you have the extra pennies lying around you could just pull the 260 (save it because there doesn't seem to be that many around) and put a 302 in it. You could then do the mods on it.
I agree if you ever decide to go original or get more buck when you sell it change the drive train to 6 bolt. Plus parts are easier.
On a side note the 260 heads do not have the smog bumb like later models do. Easier to port and get gets numbers if you put some time and money into them.
C
chrlsful
278
37
38
Lawrence Swamp, S.Amherst, MA
Mar 6, 2021
#27
  • Mar 6, 2021
  • #27
I see this older thread but still have interest (as I got both a 260 & a 255 motors lyin around). On this 260, no Zero deck suggested, no CFM cite, higher ratio rockers IDed by company, or references on largest sz valves (by oe application) IDed for me to purchase/test out. Who could I talk to who might have hop-up directions for either of these engines. I can cc a head, degree ina cam but the finer stuff (math needed, sourcing/choosing optimal prts) would B beyond me...which might be a better motor to choose is probably where I need to start. Got several cars to put it in (falcon, '83 LTD wagon) & an OD auto transmis. Thnx~
First Prev 2 of 2
A
Please!? I need some help with my 1964.5 alternator conversion
  • Alabear94
  • Dec 6, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
GOvert
G
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
J
68 Mustang with Foxbody Engine Stalling Issues - MSPNP2
  • JayV68Stang
  • Mar 13, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Mar 13, 2025
JayV68Stang
J
