Suggestion for camshaft. Help appreciated.
7Srancher
Houston
Hello all,
Beginning my first time build of a 347 stroker in a 66 Coupe. I will be running the Eagle stroker kit with flat top pistons, 030 over bore. Have AFR 185 heads and plan to get an edelbrock air gap intake. I want to stick around 9.5:1 compression ratio to still be able to run pump gas. Was looking for recommendations that will work well with my planned setup and have a decent idle as this will be more a street than strip build. I wouldnt really plan on going much over 6000rpm.
It is my understanding that most of the newer camshafts are steel and will require a new distributor gear to match that way they dont leave shavings, this the case?
Any help or advice would be appreciated.
Thanks!
CAMTWO1070
163
48
38
NY
You can go as high as 10.5:1 and still be able to run pumpgas. I'm running a tad under 10.5:1 in my 410 stroker I run 93 octane and theres no pinging...
As far as distributor gears...You go with what is recommended by the camshaft manufacturer.. To save alot of confusion and compatability issues I always run a melanized gear on my distributors to be perfectly safe..
I go by the 128 median as a rule when choosing a camshaft.........You get the most bang for your buck using that method and is a proven method thats not used by camshaft technicians when you trust them to pick you out a camshaft..
When you call a camshaft manufacturer and a technician gives you a camshaft recommendation wait a day and re-call and I bet you get a different tech with a different recommendation too then compare their choices against the actual 126 formula for SBF........LOL
LSA=126-(CID/8/valve diameter x .91) & to figure out duration of IL you use this formula.. Overlap/2 (LSA plus divided overlap) x2 equals the duration of intake lobe needed.
Im running a high torque low rpm hydraulic flat tappet camshaft in my 410 stroker...with a A9L /Moates Chip plus AEM WB02 controller and my camshaft has under 220 duration w/.477"/.493" lift @ 1.6 ratio but running 1.7 ratio shaft mounts so lift is .503"/.524" and camshaft also has a 111* lobe separation...Im also running Edelbrock E-Street heads w/small valves and running flat tappet hydraulic EDM style lifters and Trick flow dished pistons that sit .042" out of the hole too..
When you build a perf engine for the street you want the piston flush w/deck height or a lil above...To keep a descent quench Im running Cometic MLS gaskets that are .092" thick and was a special order too as theres different gaskets for different apps ..My gaskets are made for cast iron block and aluminum heads to get a perfect seal...
Hp is 494 @ 5200 ...Tq is 568ftlbs from 3300-4300rpms and 509 @ 5200 with Edelbrock EFI Performer intake #3881......
When you can build an engine where torque and hp doesnt crossover & the torque number tops the hp throughout the whole rpm band you have yourself one baddazz mofo and one fun ride for the street & strip ...LOL
Even motorcycles rely on torque over horsepower to make their power .......
Whats awesome is my vehicle is a daily driver and at last topoff in my 33 gallon tank with a lil under an 1/8 tank still showing on the gauge netted me 604 miles on the odometer and most of those miles were city driven miles with a 5 speed...
Back in 1991 my vehicle when brand spanking new and only had 220hp plus riddled w/epa devices was rated at 12-15mpg ...LOL
Good Luck
