- May 24, 2011
- 10
- 0
- 0
Have a set of XE262AH comp cams and Beehive 26113-16 springs installed in a 97 Mustang with the PI heads. The Passenger side cam is making a tapping noise and at first the tapping noise was at all RPM and dealer said three would not pump up with oil. So the dealer replaced the three they suspected of being the issue (although, I though you should do all eight) Now they are telling me that the tapping noise and oil issue is at higher RPMs. The dealer did not tell me if the issue was with the same lash valve adjusters that were replaced. Does not seem to be something simple like air in the lash adjusters. The Driver side head seems to run perfect. Any suggestions on this issue??? Has anyone experienced this problem with this set up? Ford seems incapable of fixing the issue...
