275x18s up front
I had 275/35's on 18x9 Bullits up front on my old stang and never had any problems with rubbing. I was lowered with Steeda springs though, which aren't that extreme of a drop.... :shrug:
WasteGas said:
Anybody lowered w/ H&R and Bilstiens running 275/35/18s up front?
Will I have rubbing problems with this tire size?
Thanks.
I have bullitt suspension and my 265/35/18's rub on really full lock turns, but if you are talking about outside rubbing can't help ya. i would advise my tire size tho.. looks the best and doesn't track too bad either.
-wade
Here's the result
:banana:
I have exact setup you're asking about. H&R SS & 275/35R18 Nitto NT555s on Y2K Cobra Rs. When I turn REALLY sharp I hear something rub...and only one or two times I've had the tires rub while driving....one time was during a hard turn and I was doing about 60mph.....I hit a dip. I can't see any sign of damage to the tire at all...so I think it was just the plastic fenderwell.
I would do this same setup all over again.
I have installed my wheel/tire/spring combo few weeks ago. I have tiny bit of rubbing prob. only time it rub anything is when I'm left full lock. edge of tire is slightly touching sway bar. If you go slow turn, then It doesn't rub. Hope this helps!
