Uh, the above advice from Z06... should not be taken if you have stock-spec 66 heads from an A or C code motor. You haven't stated otherwise, so I have assumed that you do not already have screw-in studs, deepened spring pockets and a spring upgrade - all of which, I think, would be required for a .550" lift cam.
Tell us more about your heads.
