Short history... 289 with a motorcraft 2100 carb. It had a stall problem after 30 min of driving. We replaced the fuel pump (old one was well worn) ignition coil to a flamethrower, the car has pertronix instead of points and inline fuel filter to the carb. Took off the carb and put a new gasket on. Now the car has a misfire under acceleration... Ok at idle and if you feather the throttle it is smooth. But as soon as you give it a little gas and accelerate (not even that hard) the engine sounds rough and shakes.. it still accelerates but not as fast as it should... it eventually smooths out once you stop accelerating.
Is it a timing issue... could it be the carb... not producing enough vacumn advance with the new gasket? It didnt have this problem before we changed the above parts... oh yea, we changed the PCV valve too.
Thoughts?
Thoughts?
