1g vs 0g wire for battery relocation
its time to get some weight off the front end the first thing to go is the battery. i want to know if 1g wire is thick enough. ive heard you should run nothing smaller then 0g but summit sells a bunch of kits that are all 1g which makes me thick it will be good enough. what do you guys thick. i want to order my wires soon cause im about to put in a bigger fuel pump so with the tank out, i figured it would be easy to drill for the battery box.
thanks guys
<--for my g/f cause she's canadian...lol
thanks guys
I got 30ft of 0g heavy duty welding cable for $30. Most welding shops will even sell you the copper(better than lead IMHO)ring terminals need to ground the battery. I never understood why most battery relocation kits sell a 1g wires for power and a 2g wire for ground.
I made my own kit, and have not had any problems. Good Luck.
