2v 351C heads or 4v 351C heads 1972 mustang
wulk025
25
Arizona
Ok so Three weeks ago I found a 1972 mustang no joking in an elderly mans shed. I ended up buying it from him and now starting to do a restoration on it. Now the VIN says that this babe has a 2v 351C but on the heads in the top right and left corners of both heads are the number 4. Now from my under standing, is that only the 4v 351C had this stamping and the 2v 351C had the number 2 stamped on the heads. So I went back to Bill and asked him if he had ever had the car worked on or the heads changed out and he says no. And yes he is the original owner of the car. Any feed back would be great on wether this is a mess up by the Manufacture or what?
Hmmmmm.....
I don't know about that one man.... From everything that I have researched, the 4 stamp indicates 4V. It seems like you know how to read your VIN correctly. You can go to TheMustangShop to validate it. If you are doing a restore anyway, pull those suckers off! :D
Are you sure on the VIN info? Post the info from your data sticker on the door jam. Does it have the "H" in the fifth digit location? If it has a "Q" or a "R" it should have 4V heads. Does it have a 4V carb and intake? If it has a 2V carb and intake on 4V heads, it wouldn't run very well.
