2v Intake Question
  • Thread starter Thread starter SHOWTIME!!
  • Start date Start date Jan 4, 2009
SHOWTIME!!
15
  • Jan 4, 2009
Im looking at buying a intake for my 99GT. I am going to be spraying about 150-200 to it so i am going to for sure need to get rid of that plastic junk. I only know of 3 intakes that are good for the street/track for 2v. Edlebrocks victor jr, trickflows track heat, and professional products typhoon. Which one would be the best for the money? Are there more intakes out there that i just dont know about? Thanks guys.
BTW, MMR just came out with an adapter plate for the edlebrock intake that allows you to use your stock throttle body and plenum on that intake. So now you dont have to buy a $200 plenum from edlebrock!!
tag4car
Birmingham AL
Jan 4, 2009
  • Jan 4, 2009
thats a big shot for stock internals, i assume stock given your sig
SHOWTIME!!
15
  • Jan 4, 2009
it has internals out of an 01 cobra
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Jan 4, 2009
  • Jan 4, 2009
Thats still a healthy shot. Have you looked into the Hardball'r intake? I've heared too many bad things about the PP typhoon(people say you need to grind out some of the casting flash inside it), the TFS one has a good reputation though. The stock intake will hold a 150 shot, just make sure you don't spray any lower than 3 grand and you should be good
Tim2002GT
635
Tulsa, Oklahoma
Jan 4, 2009
  • Jan 4, 2009
I've also heard good things about the THR Hardball'r intake. The Fox Lake P-51 is also a very good choice, but it is pricey.
Stark77
501
Tallahassee, FL
Jan 4, 2009
  • Jan 4, 2009
I had the Typhoon and it was a good intake manifold for the price, but required lots of dremel work to clear out the casting flash. Next one I buy will be the Trickflow Trackheat, it takes the Bullitt design and improves on the lower runners. Compared to stock, hardballer, or typhoon, it will generate very noticable gains in the low end which is what you'll need because you shouldn't spray until 3k RPM.
mustangman9812
661
Mars Hill, NC
Jan 4, 2009
  • Jan 4, 2009
Hardball'r +10000 best intake I have tested so far! Not on my car but friends.
blckstng96
208
  • Jan 4, 2009
01 cobra internals arent going to help you out,u may have the forged crank now but you still have **** rods.i wouldnt spray over 150 on that.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 4, 2009
  • Jan 4, 2009
did the 01 cobras have a forged crank??
either way the stock internals will not handle a 200 shot
BurningRubber
1,865
24
58
Jan 4, 2009
#10
  • Jan 4, 2009
  • #10
Yep, crank is forged... rest is chit.
I know of two people that have sprayed a 200 shot on stock internals. 1 made it, 1 didn't.
One is on here, 04GTMustangs' survived but I think he said he only sprayed it once at a 200 shot. The other guy was in our local group and he destroyed a piston after a short amount of runs.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jan 4, 2009
#11
  • Jan 4, 2009
  • #11
anyone wanna make some bets???
SHOWTIME!!
15
#12
  • Jan 4, 2009
  • #12
If it blows it blows...if it doesnt then it doesnt. It's only money, we can't take it with us. Have ya'll heard anything about the edlebrock victor jr's?
Stark77
501
Tallahassee, FL
Jan 4, 2009
#13
  • Jan 4, 2009
  • #13
The Hardball'r and the Typhoon are virtually exact copies of the PI manifole - one is steel, one is aluminum. I haven't read any performance reviews of the Hardball'r, but it's definitely beefy enough to handle gobs of boost/nitrous. The P-51 has dyno proven gains of about 15rwhp on a bone stock 4.6v engine - but it's almost $1300.00 with the required fuel rails, alt mount, etc. I've been hesitant to buy a new intake manifold since selling my Typhoon in case I decide to use part of my tax return for this year on a TorkTech unit
BurningRubber
1,865
24
58
Jan 4, 2009
#14
  • Jan 4, 2009
  • #14
The Edelbrock is a great high-RPM intake with it's short runners, but I doubt it would do much for retaining any low end. It would be fine for nitrous because it is aluminum and it's a pretty short/straight shot for the nitrous to flow into the cylinders.
D
darkside03gt
851
Sacramento CA
Jan 5, 2009
#15
  • Jan 5, 2009
  • #15
Do you have any dyno sheets? I have been looking at the hardballer and have been concerned with the shorter runners since I run a vortech and cant afford to loose any low end power. what kind of gains did you see?
Stark77
501
Tallahassee, FL
Jan 5, 2009
#16
  • Jan 5, 2009
  • #16
That BBK intake that is coming out *hopefully soon* is the best, in theory, that I've seen yet with its dual length runners that are controlled via butterfly valves.
blckstng96
208
#17
  • Jan 5, 2009
  • #17
yeah but who knows when that bbk unit is going to come out.but if and when that happens the that would be the one to have by theory.
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
G
Supercharger Options 5.4 32V Intech
  • Germangazguzzler
  • Apr 19, 2025
  • Other Auto Tech
Other Auto Tech Apr 23, 2025
RaggedGT
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
W
Blue smoke..
  • Wicked_Rpm
  • Aug 11, 2024
1996 - 2004 SN95 Mustang -General/Talk- Aug 14, 2024
weendoggy
