3 Core vs 4 Core Radiator
Red66GT
214
Simi Valley, CA
My radiator recently sprung a bad leak and I'm considering getting a new 3 core radiator. I currently have a 4 core and the car barely runs 180 degrees in near 100 degree weather.
If I switch to a 3 core (since they're much much cheaper and I'm on a budget) how much hotter do you think my car would run?
I may also just try to get mine repaired if 3 cores suck, any thoughts?
It might just run cooler with the decreased airflow resistence of the 3 row over a 4 row. A 3 row will allow more airflow thru it over a 4 row. And running 180 in 100 degree weather is PERFECT. Wish my V8 Ranger would do as much. It runs 200-220 in 90 degreee weather.
I ran a 3 core with a 5.0L with a/c in my '65 with no problems even in +100 degree heat. That said, the larger the engine overbore the more cooling you need.
