thats not exactly true the way it was explained.
both add fuel and nitrous, just in a different way.
a wet kit sprays fuel and nitrous through the same jet (if it's a nozzle kit) or through the same plate w/ a spray bar (if it's a plate kit) or through individual nozzles..separate for fuel and nitrous (big shot...high hp app's
direct porting)
a dry kit sprays nitrous only through a nozzle, and adds fuel by spiking the fuel pressure.
there is no need to run an adj. fpr because the kit spikes fp to about 40-42 psi when on the juice.
of cousre , having an adj. fpr is nice to tune...if your running 45 psi all the time your just gonna rich as hell all the time and foul out plugs. a lot of 5.0's tend to run rich from the factory, and you make less power. you actually want to be as lean as you SAFELY can be.
ok w/ that being said....there are pros and cons to both wet and dry kits.
if you plan on spraying 100 or less, just go dry.
if you want to spray 150 or more, go wet, but i don't like the nozzle kits, because you get fuel "puddling" in the intake, the 5.0 is meant to flow air through the intake not fuel.
so you get backfires from a wet nozzle kit since you spray into the upper.
a plate kit that sandwiches between the upper and lower is good to go, because the fuel is spraying into the lower intake.
wet kits take longer to put on take off.....dry kits are a since.
i can do a zex or NOS dry in about an hour and a half.
the zex is the easiest, i have used both but actually prefer the NOS. the edelbrock dry is a direct copy of the NOS , but i haven't used it b4.
the best setup you can have for safety and ease of use, should have a fp safety switch(comes w/ kit..shuts off nitrous if fp drops)
wot switch (comes w/ kit...either tps or micro)
msd (6a or 6al if you like....good to have reliable spark)
msd window switch ( sets the rpm points at which the nitrous will spray...shuts off at upper rpm limit even at wot)
also , i believe the new window switches from msd not only control activation rpm...but work like the tps wot switch.
the zex uses a tps wot switch the NOS and eddy kits use a microswitch and it's not as precise.
ok trying to not make this so long...... your definitely gonna want cheater slicks...radial or not
my vote for ease of use and ease of install is the zex or nos dry kit.
