1. I just took my 00 4.6 apart and in the intake valley, there is a small treaded hole that had nothing in it. In my new mmr 900, the same thing is there and am curious to why it's there.
2. Does anyone know the valve clearances with 18cc dished pistons on my stock heads? 2000 4.6 GT. (I know this is pretty technical but if anyone has it, it would be appreciated)
3. Also, I am installing cams in the heads (which are done) and am now going to find TDC. I looked in my haynes manual and I could only find how to get your cams at TDC if you don't take them out. So the question is, how do you put your new cams at TDC. The new cams don't have a fitting for a cam tool.
anything would help, thanks
