3 speed to 4 aod...
  • Thread starter Thread starter restomod22
  • Start date Start date Apr 15, 2004
R
restomod22
87
Cincinnati, Oh
Apr 15, 2004
  • Apr 15, 2004
I have a 65 mustang coupe w/3 speed auto. What is the best route for getting a 4?? Can I use other trannys from other cars?
Thanks for any suggestions...
J
jscar1968
28
Santa Ynez, California
Apr 15, 2004
  • Apr 15, 2004
Hey, I have a 66 mustang w/ a 289, almost totally done now. I went with an aod transmission from an '84 t-bird. It turned out pretty decent, even though it hasn't been driven much since I've been doing the prepping for paint. Cost rounded out to about 500 bucks. 250 for trans, 125 for the xmember, 60 for the flywheel, and I really didn't have to replace the driveshaft but I did anyways...Another 400 bucks damage. Oh and the all important throttle valve cable and set up. I don't regret it at all. Last time I had it out on the street the difference was awesome.
R
restomod22
87
Cincinnati, Oh
Apr 15, 2004
  • Apr 15, 2004
hey thanks
do you know if later model fox body trannies are compatible?
J
jscar1968
28
Apr 19, 2004
  • Apr 19, 2004
Yes, they'll work. the biggest pain with the aod is setting up the t/v cable, they are all pretty much the same. but you need to buy the cable vs using the linkage that comes with some of them. Remember that you have to change the flywheel, and it has to have the right counter balance weight in it. So you can't use the one that came off of the latemodel, unless you have a late model engine. Also with the later models, don't get the ones with a computer controlled tranny. That would make it an aode. Let me know when you get started. Good luck!
Edbert
3,548
32
109
Austin TX
Apr 19, 2004
  • Apr 19, 2004
Just make sure you get one early enough that is uses the TV cable. The latter ones are electronically shifted. I don't know which years saw the cutover, it was probably a different year for each car. Lincolns and T-birds first then mustangs then trucks.
If you are doing anything high performance be aware that the stock AODs were notoriously weak in a few areas. This can easily and cheaply be overcome by buying the appropriate parts. For normal street driving with a normally powered motor you'll probably be fine with a stock AOD though.
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
D
New Guy In Ga.
  • Driven65
  • Oct 20, 2025
  • The Welcome Wagon
The Welcome Wagon Nov 11, 2025
Driven65
D
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Y
Speed density 302 to carb 351W
  • yaboity
  • May 29, 2026
  • Fox Engine Swaparoo
Fox Engine Swaparoo May 29, 2026
AeroCoupe
