30 lb injector woes
  • Thread starter Thread starter 93lxtwin
  • Start date Start date Dec 9, 2010
First Prev 2 of 2
R
Rick James
172
burlington new jersey
Dec 19, 2010
#21
  • Dec 19, 2010
  • #21
93lxtwin said:
So, does anyone have any idea about those switches on a hypertech chip?
Did you try calling hypertech?
93lxtwin
37
Wilmington, NC
Dec 19, 2010
#22
  • Dec 19, 2010
  • #22
No, not yet. Figured I'd use some of the resources here on the forum and see if any of you guys knew what they were used for.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Dec 19, 2010
#23
  • Dec 19, 2010
  • #23
I would not touch them , they were probably used in the original programming of the chip , I doubt changing them will actually do anything but probably screw something up , the EEC reads the ROM on the chip and turns off the internal ROM in the ECM and overwrites it with whatever is programmed on the ROM of the chip , I have read a hypertech chip and can tell you the only changes they make is to make it run RICH at WOT and they max out the borderline spark table which any true tuner will tell you is a hack job at best , you would be better off to just add 4lbs of fuel pressure and crank the distributor to 20 degrees base timing as to run a hypertech , COMPLETE JUNK , I can post screen shots if you wanna see what im talking about
93lxtwin
37
Wilmington, NC
Dec 20, 2010
#24
  • Dec 20, 2010
  • #24
I'm sure you're right. I took the thing off my computer anyway. Still chasing this injector issue. Been in contact with C&L, waiting to hear back from them. I think I have the wrong tube in the mass airflow housing. Could be my problem. I will let all of you guys know when I get it worked out.
First Prev 2 of 2
G
Fox Looking for old Hypertech part
  • GOvert
  • Jun 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2025
gkomo
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
  • dan50
  • Jul 18, 2026
dan50
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
