All,
I need a new intake manifold as my Cobra manifold is cracked and broken.
Mods are in sig, but in brief, I run:
stock heads/cam
stock bottom end
4.10s
3000 RPM lockup torque converter
125 shot of nitrous
Now, I'm tempted to go with an intake manifold with a 1500-6500 (Track Heat, Typhoon) powerband because of my 3000 RPM stall speed...but, will this cause a flow issue and loss of power with my stock heads?
Would I be better off with an idle-5500 manifold (Street Heat, Eddy Performer)? If I wasn't running a 3000 RPM stall this would be a no-brainer.
Basically, will a 1500-6500 manifold create a loss in horsepower above 3000 RPM for my stock headed/stock cammed car? Or will it only hurt down low and make MORE power up top than a 0-5500 RPM manifold?
All searches of the forums have yielded is that the 1500-6500 manifolds lead to a loss in low end power...which isn't a factor for me because my car stalls at 3000. I want to know how it effects performance above this for stock headed/cammed cars.
Input is welcome. Thanks.
stock heads/cam
stock bottom end
4.10s
125 shot of nitrous
