Ok guys, This isn't my first time around the block. I have run 12.8 with a 289 with nothing more than a solid cam with 274/475 stock heads, No Porting, headers 1.5" F4B and a Holley 650. I know how to make power and fast E.T. The goal with this build was not as easy because of the self imposed limitations. I want to not have to completely rebuild the car if I go sell it or show it in a stock class. But I also wanted a car that is fun and economical to drive. I have camouflaged the RRS front end by keeping the stock shock braces in place and cutting the the top of of a couple of old shocks. No one has yet picked it out at a car show with out me showing them. And the reason for the RRS and not some other brand is that it only takes a few bolts to change back. No cutting no drilling.
The guy who is all wigged out about these heads has never had to make power the hard way. Before there was 20 company's making aftermarket heads! I will put these 351w heads flow data up against many so called out of the box performance heads and blow them a way. I know a set of AFR 185s would kill these but for my goal these are not the bottle neck.
By the way these were professional ported on a flow bench. The reason I'm using them is because I have them from years ago. If I were to buy ever thing new I would not start with these. I did have to port the exhaust manifolds to get a port match to the heads
This by the way is a 306 cu in motor as I did install a 3" 302 crank. The block has nothing to do with making power. What kinda crack was he smokin. I can put a more aggressive hydraulic cam in an help the problem but I am concerned about highway cruising rpm and the power band being to high. I believe that I can get there with the combo I have. I may need a little more intake but that will be the last thing I change. Doing the distributor re curve fist and I will report back.
By the way Iron heads will always make more power than alum because they don't dissipate the heat which is power.
With iron heads you can safely run nitro-methane!
Hmmmmmmmmmmmmmmmmm:Teh-Win:
