My Engine Info Sent to Ed Curtis
95Vert383AOD
1,133
34
69
New Bedford, MA
Heads on this Combo are god awful. I wonder what Head he recommends for heads. :shrug: He sent me a Price sheet two 205 combinations and two 225 combinations.
~Chris
Type of Camshaft Requested: - Hydraulic Flat Tappet [] - Solid Flat Tappet [] - Hydraulic Roller [x] - Solid Roller []
Body Style/Type: Coupe Mustang 1995
Weight With Driver: 3600
Goals and Usage: Street/ Some Strip
Engine Details
Make of Engine: 351W Deck Height: 9.5
Cubic Inches: 383 Bore and Stroke: 4.030/ 3.75
Compression: 9.0:1 Piston Type: Srp “206063” 4032 Forge
Rod Length: 6.2 Rod Type: Eagle H Beam
RPM Range Desired: 2000 6500 Whatever is most optimal
Cylinder Head Details
Manufacturer: ProComp Part Number: PC3038
Ported or Stock: Stock If ported, by whom:
Valve Sizes: Intake: 2.02 Exhaust: 1.6
Port Volume: Intake: 210cc Exhaust: 70cc
Combustion Chamber Size: 64cc
Flow Figures (.100" through .700")
Intake Exhaust
.200 101.5 -91.1
.300 146.7 -131.0
.400 194.1 -160.0
.500 233.4 -170.3
.550 - -
.600 255.8 -173.8
.650 - -
.700 262.0 -177.0
Valve Spring Pressures: Closed: Open: Rate:
Rocker Arm Ratio: 1.72 Probe Shaft Style
Induction Details
Intake Manifold Type: Trick Flow Stock or Ported: Stock
Throttle Body/Carb Size: 90MM Stock or Ported: Stock
Exhaust Details
Manifolds [] Shorty [x] Mid-Length [] Long Tube []
Primary Size: 1 7/8 Collector Size: 3”
H or X-Pipe: X Exhaust Diameter: 2.5
Type of Muffler: Full Exhaust [x] Dumps []
Transmission Details
Manual [] Clutch Type:
Automatic [X] Converter Stall: 2400
Transmission Gear Ratios:
Drivetrain Details
Rear Gear Ratio: 3.27 (Will be swapping to 3.73)
Rear Tire Size: Diameter: 17” Rim 35 Profile ??? Width: 315
Power Adder Type
Nitrous: HP Level:
Turbo: A/R:
Supercharger: CFM:
Previous Camshaft Manufacturer:
Specs Intake Exhaust
Lobe Lift: .510 .534
Duration @ .006” 289 299
Duration @ .050” 222 232
Duration @ .200” - -
Lobe Separation: Intake Centerline: 107/117
Engine Management System: T4M0/ Moates QH
Special Issues: This Combo Made 497.3 lbs Tq @ 2000 RPM 265Hp @4000 power dropped pretty quick after these Rpms
CONTACT: www.FlowTechInduction.com
Thanks, ive gotta see what he recommends for a head. I do have Shaft Rockers and a pretty massive intake....so 225 might not hurt. But i did want to keep the RPMs below 7000. Whats awesome is that hes in state. So i can go pick it up myself.
So are you just getting a cam from him or more work? What prices did he send to you? Interested because I was looking at a 393 stroker kit from fordstrokers.com and definitely wanted to get a FTI cam. PM me if you dont want to post numbers here.
how much do you want for the heads
$750 Shipped They have 1/2" holes so you'll need dowels if its going on a 302. I had them O-Ringed so they'll be good if you're running nitrous, S/C Etc.
These heads have 210cc Runners but the actual flow numbers are comparable to a AFR 165cc. It includes Valves/ Springs/Retainers/Bronze guides. No studs or guide plates. Springs are good up to .600 lift. If you live close enough and don't know how to install heads ill install them. :D (For the right price of course)
Ed is the mad scientist in the hills. Good thing we have e-mail. LOL....if theres a problem i will personally drive to his shop and leave an email on a brick. :D J/k
A N/A SBF combo isn't hard to figure out. I gave him plenty of info.
As for the heads They're on my engine right now. They're in excellent condition seeing as i put them on about a year ago and the car doesn't get driven much. I'll either toss them on E-bay or toss them on the short block 302 in my garage. and start building a second motor.
UPDATE from Ed Curtis
Afternoon Christopher,
I did run through quite a few calculations using the AFR 205 heads and the AFR 225 heads as well as various camshaft profiles and we would be looking a project with close to 525 HP with the 205 heads. As long as the headers are a match up to the exhaust ports of the AFR 205 heads. About 25-30 more with a big set of tubes made for the larger 225 exhaust ports. Quite a stout powerplant.
Let me know when you're ready and we can get this done.
Ed
So whatcha guys think?? AFR 225??? :shrug:
Thats more power than i planned.... If i made around 550hp with this N/A setup i would be excited!!!!
