302,306,331,347?
mustangsally93
281
Omaha,NE
1.) Well I’m looking at up grading the pony. I got the stock 302 in there and it smokes and eats plugs. So I want to doan up grade. I just don’t know what to do. I want something nice. I got a ford racing T-5 and a spec clutch (3+) so I know well be good there. Something maybe around 450hp, with out going with a blower or turbo. I’m going to keep the nitrous but only like a 100 shot. What do you guys think?
2.) I going with the baer kit for brakes so that’s good. Also I want to put 315 in the back. How hard is that going to be? What about going with tube front a arms? (I know I well have to get the fenders flared to fit 315 in the back).
3.) Can I talk body work in there or do I have to go to talk?
Thanks guys
You could do a 302/306 but it would take more to get there. The easiest way to get to your goal would be a 347. Figure around 350hp with a good setup on pump gas conservatively and put a 100shot on it and you have your goal.
You probably should have chosen a different transmission for your combo.
My brother bought the tranny back in 94. The car only has around 36k on it. I was thinking about a tko 600.
If you have nitrous to assist you, the 331 and 347 will get you closer to your goal. Stock block eh?
I might suggest the 331, more piston material than the 3.4" stroke engine (347) and a the rod ratio is a tick less extreme, which doesn't matter in aftermarket blocks near as much, but with a stocker...I wouldn't push it.
Get a safe nitrous tune and a 331 or 347 will get you there.
I'm using mega squrit for my tunning. Should I use my stock block or just stop being cheap and get a dart block?
A 351W block is stronger than a 302 block.
A Dart block would be great, but it is costly, with the block price, and the internals, extra machining, and assembly...you could easily spend 4,000 bucks on a shortblock.
Good Luck!
Good Luck!
HAHAHA thanks. What about a 351 roller out of a truck and just rebuild the bottom end and put on a nice top end?
5spd GT said:
Post up when you split the block:)
sounds like he wants to stay under the limits of the stock block. I would suggest a 331 with the stock block and use a 100 shot. Like people said before that will get you to right around the number your looking for. With a safe tune you should be fine.
Yep, look what I posted near the beginning:)
Nitrous makes things a bit less predicatable than all motor. The block may or may not last...
Grn92LX said:
Late model 351 blocks are no stronger than late model 302 blocks according to my builder.
I would build a n/a 331 or 347.
:nice: That is exactly what I said, the latemodel 351W will split right up the middle just like the 302. If your looking at 351 goes 69-74 they are the thick web blocks and can hold decent power levels.
