302 and 12 MPG...
aldeswarii
Ok, so my recently rebuilt 302 is getting horrible gas mileage (about 12 is the best I've had) on 2.70s and a rebuilt C4.
302 .030 over
Edelbrock Performer Intake, Cam, Lifters, 650 CFM Carb ( All from a kit )
Pertronix Flamethrower
I don't get it. :shrug:
Mine is about the same except I usually get 10-11mpg (highway). I'm running 2.73s and a C6. My mods are Edelbrock cam, 351W valves, all new valvetrain, port and polish, .020 over, pertronix ignition, etc. (I know I'm leaving stuff out, check out my website for a whole list.) I don't know what it is either, and yes it is tuned right.
there are a number of things that affect fuel economy. they are;
1: carb jetting
2: float level
3: fuel pump pressure
4: vacuum leaks
5: ignition timing
6: vacuum advance(or lack there of)
7: gearing
8: driving style
9: carb size
10: state of tune
11: compression ratio(or lack there of)
12: exhaust problems
13: acclerator pump output
etc. take these one at a time and fix any problems first. then work on your driving style.
302 .030 over
How does it run? 12 mpg doesn't actually sound that bad to me if you're driving it hard in the city. Now if that's all gentle highway cruising at 55 mph, 12 is bad.
It's also possible that you have a fuel leak.
I don't really understand why classic car owners get all upset and worry about gas mileage. Just drive it and have fun. If it isn't performing well, sure do some tuning. If you're after great fuel economy, putting aftermarket performance parts on the car is NOT the way to go.
Buy a Yugo or a Chevette. They get better gas mileage.
i must be doing well. i get 14-16mpg. set up is
69 grande
302 stock
600 cfm edelbrock carb
pertronix II ignition
t-10 4-speed
whatever gears were from the factory for a 69 grande 302 automatic
Have you attached a vacuum gauge with a long hose and looked at it while you drive around town or down the highway?
Driving style can affect mileage more drastically than many folks realize. I got 21.8mpg from my 05-GT last tank but many folks in the 05 forum are seeing 15-16mpg.
Does seem a little low for the performer setup. When I had that similair setup I was getting about 15-16 but that was alot of hiway miles. Now with the bigger cam and different heads I am geting around 14.5
Oh and c4 with a 3.00 rear gear.
cruising at 75 with 2.80's i got about 16/17 mpg with eddy performer setup
trip from my parents to norman is about 155 miles or so and it took just over half a tank
when the points went bad, the gas mileage did drop alot though
