302 blocks
  • Thread starter Thread starter lincoln+ford
  • Start date Start date Sep 28, 2009
lincoln+ford
195
  • Sep 28, 2009
Im building a 331 with 185 afr's n-71 cam and parker funnel web.I want to hit it with a 150 200shot.But im worried about the block.The block i have so far is a sn95 block.Ive been reading that the older pre 82 blocks are heavier because theres more nickle in them?Anyone know if this is true?Also i plan to 2 satge or progressive controller to make it less of a hit.
304billet
315
  • Sep 28, 2009
a 331 with a 150/200 shot will split the stock block. forget about the 185's go 205's.
u have 4 choices - mexican block or aftermarket race block, SVO R, dart or A4.
skunk21
1,203
Taxachusetts
Sep 28, 2009
  • Sep 28, 2009
not true to the bset of my knowledge, the older pre-1980 blocks where made using the old non-thinwall casting design called a middle weight but this had nothing due to the strength of the block itself (This blocks also had other provisions on it for lincoln). the 1980 and later blocks ( not the mexican) use the thinwall casting, the blocks where upgraded again in 85 for roller lifter and again in '86 with thicker decks, cylinder walls etc. The mexican "middlewight" blocks are casted like the older 79's but they don't offer anymore strength to the block itself. If you blow the block invest in a dart or world, once you get to that 500-520crank hp range it's time to start thinking that way.
lincoln+ford
195
  • Sep 28, 2009
Cuz my buddy has a 69 block out of his fairlane.Didnt know if that was stronger then the standard 302 efi block.
lincoln+ford
195
  • Sep 28, 2009
pay for the 205's and i will other wise im using what i have.
Engine 302 production block selection
  • FastDriver
  • May 19, 2024
  • 2 3
8K
Fox 5.0 Mustang Tech Jul 1, 2025
FastDriver
Progress Thread Akumu No Dara Ra's LSX swap and build Thread! Updated (2/10/22 @ 8:30PM CST)
  • Akumu No Dara Ra
  • Feb 4, 2022
  • 6 7 8
17K
1996 - 2004 SN95 Mustang -General/Talk- Jun 17, 2022
Akumu No Dara Ra
M
Progress Thread Monkeybutt2000's 89 vert build thread- 408w build in progress
  • Monkeybutt2000
  • Apr 4, 2020
  • 20 21 22
73K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 20, 2026
2Blue2
On3 Performance Install Tips
  • flstang65
  • Dec 15, 2019
12K
1996 - 2004 SN95 Mustang -General/Talk- Mar 17, 2023
atomicfox236
A
N
SOLD Supercharged 1989 SSP Coupe $13,500 obo
  • notchlubber
  • Jul 17, 2018
13K
Fox Body Mustangs For Sale (1979-93) May 28, 2020
notchlubber
N
